Mesh network
gustavo.pena
Frequent Visitor
Frequent Visitor
I'd like to know if there is a constrain regarding what models of APs could be used as MAP or RAP in a mesh network. Every AP could be used in this kind of configuration? (for example AIR AP 1130)
Leo Laohoo
The only indoor AP's that can be used as mesh are the AP1130 and AP1240. Indoor mesh access points (1130 and 1240) can function as either a RAP or a MAP. By default, all are configured as MAPs.
Converting Indoor Access Points to Mesh Access Points
http://www.cisco.com/en/US/docs/wireless/controller/5.2/configuration/guide/c52mesh.html#wp1574088
Hope this helps.
Yes thats the answer I was looking for, thank you very much.
