Mobility Anchor/Foreign WLC code versions
Josh Morris
Level 6
Level 6
I am trying to setup a mobility anchor (5500 version: 7.2.111.3). I need this version as to support the Bonjour gateway.
The foreign WLC is a WiSM-1 (version: 7.0.220.0).
I have control/data path up. I am able to ping through it. I am, however, getting invalid mobility packets to the foreign WLC from the Anchor.
Do the code versions have to be identical for a mobility anchor? I do not plan on perofrming any AP roaming to the anchor.
Thanks.
20 Replies 20
To add clarification for my benefit.
If you configure an open ssid and anchor from the foreign / anchor does it work -- yes/no
if you configure open ssid with webauth does it work -- yes/no
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
With an open/open without any Web Policy, the client can connect and pass traffic.
With open/open with Web Policy, the client can connect (get an IP) but not hit the auth or passthrough page.
Ok lets talk web auth ..
You select web passthrough. Are you using a 3rd party page or are you using a local page, custom page ? Where do you have it pointing ?
I have been set to the internal default page on all L3 web policy.
Attach a txt file of the show wlan on both the foreign and the anchor.  Also the show interface detailed virtual on both.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Output below. Anchor first.
(Cisco Controller) >show wlan 1
WLAN Identifier.................................. 1
Profile Name..................................... pn
Network Name (SSID).............................. pn_test
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Disabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Client Profiling Status ....................... Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
Number of Active Clients......................... 0
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ guest-dmz
--More-- or (q)uit
Multicast Interface.............................. guest-dmz
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Enabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
--More-- or (q)uit
   Authentication................................ Disabled
   Accounting.................................... Disabled
   Dynamic Interface............................. Disabled
LDAP Servers
   Server 1...................................... 10.4.21.177 389
   Server 2...................................... 10.4.21.178 389
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Disabled
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Enabled
IPv4 ACL........................................ Unconfigured
IPv6 ACL........................................ Unconfigured
Web-Auth Flex ACL............................... Unconfigured
Web Authentication server precedence:
1............................................... local
--More-- or (q)uit
2............................................... ldap
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Enabled
   FlexConnect Local Switching................... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
   Client MFP.................................... Optional but inactive (WPA2 not configured)
   Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
1           10.241.15.5           Up
--More-- or (q)uit
802.11u........................................ Disabled
  Access Network type............................ Not configured
  Network Authentication type.................... Not configured
  Internet service............................... Disabled
  HESSID......................................... 00:00:00:00:00:00
Hotspot 2.0.................................... Disabled
  WAN Metrics configuration
    Link status.................................. 0
    Link symmetry................................ 0
    Downlink speed............................... 0
    Uplink speed................................. 0
Mobility Services Advertisement Protocol....... Disabled
(Cisco Controller) >show interface detailed virtual
Interface Name................................... virtual
MAC Address...................................... 68:ef:bd:93:bd:00
IP Address....................................... 1.1.1.1
DHCP Option 82................................... Disabled
Virtual DNS Host Name............................ Disabled
AP Manager....................................... No
Guest Interface.................................. No
(WiSM-slot4-1) >show wlan 11
WLAN Identifier.................................. 11
Interface........................................ management
Multicast Interface.............................. Not Configured
--More-- or (q)uit
WLAN ACL......................................... unconfigured
Quality of Service............................... Silver (best effort)
IPv6 Support..................................... Disabled
Radius Servers
--More-- or (q)uit
LDAP Servers
Security
   IP Security................................... Disabled
   IP Security Passthru.......................... Disabled
ACL............................................. Unconfigured
2............................................... radius
3............................................... ldap
--More-- or (q)uit
   H-REAP Local Switching........................ Disabled
   H-REAP Local Authentication................... Disabled
   H-REAP Learn IP Address....................... Enabled
11          10.241.15.5           Up
(WiSM-slot4-1) >show interface detailed virtual
MAC Address...................................... 00:1a:6c:20:51:60
