Mobility Group - Data Path Down Problem W/ Anchor Controller
Pitreyeah
Community Member
Dear All,
I'm having a problem with establishing EoIP tunnel between two WLAN controllers on different subnets. Below is a summary of the setup:-
-There is no FW between the controllers
-One controller is 10.2.30.250 (Remote) and the other one is 10.3.30.6 (Anchor)
-I've checked and confirmed that the mobility group IP and MAC addresses are correctly configured on the anchor and on the remote
-The controllers can ping each other Mgt. IP
- on the Guest WLAN>>Anchor mobility, the Data path = Down and Control path = UP
I've been doing research about this issue all over the internet but none of the solutions seem to work. I'll forever be grateful for any assistance you can offer.
Thank y'all in advance!
Rasika Nayanajith
Assume this is AireOS controllers (5508/2504/etc).
Have you configured same virtual IP address in both of this.
Does mping/eping works ?
http://mrncciew.com/2013/03/24/mobility-ping-tests/
Rasika
**** Pls rate all useful responses ****
Hi Rasika,
The remote controller is a 5508 running software version 7.0.98.0 and the anchor controller is a 4402 running on version 6.0.199.0 mping responds on both controller but the eping does not work
Hi Rasika, I solved the problem by restarting the remote controller. Thank you so much for your assistance
