Mobility Groups/Anchor controller.
swackler
Community Member
can there be a different controller code on the anchor controller than the oter controllers in the group. It seems like I can not get guest users to work if the controller code on the anchor is different from the controller that the user is associated with.
Scott Fella
It must be the same code in order for it to work.
-Scott
Yeah I am finding that. Thank you!
