Mode Of Aironet Cisco AP
aoun.ameur1
Hi all,
Please, how can I check the mode of my aironet 702i AP (lightweight or autonomous) because I need to join it to the vWLC and I found that only lightweight AP can be joined to WLC ?
Thank's in advance
2 Accepted Solutions
K9W7
Ok, "W7" means autonomous IOS.
here is doc about autonomous ap image:
https://rscciew.wordpress.com/2014/01/04/understand-access-point-ios-images/
k9w7 – autonomous (or “site survey”) IOS
k9w8 – full lightweight IOS (this is what is bundled in the WLC .aes image, and is factory installed on “mesh” APs)
rcvk9w8 – lightweight recovery image – this is factory installed on lightweight APs, unless a “mesh” image is specified; it lacks radio firmware
and you have :
flash:/ap1g1-k9w7-mx.153-3.JAB/ap1g1-k9w7-mx.153-3.JAB"
Means its an autonomous Image.
Dont forget to rate helpful posts
7 Replies 7
Leo Laohoo
Console into the AP and post the complete output to the command "sh version".
Hi Leo,
thank you for responding,
this is the sh ver output :
AAA#sh ver
Cisco IOS Software, C702 Software (ap1g1-K9W7-M), Version 15.3(3)JAB, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Tue 02-Sep-14 19:59 by prod_rel_team
ROM: Bootstrap program is C702 boot loader
BOOTLDR: C702 Boot Loader (ap1g1-BOOT-M) Version 15.2(4)JA, RELEASE SOFTWARE (fc1)
AAA uptime is 3 weeks, 4 days, 18 hours, 28 minutes
System image file is "flash:/ap1g1-k9w7-mx.153-3.JAB/ap1g1-k9w7-mx.153-3.JAB"
Last reload reason: Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-SAP702I-I-K9 (MIPS74k) processor (revision 01) with 86016K/45056K bytes of memory.
Processor board ID KWC185002R3
MIPS74k CPU at 560Mhz, revision number 0x0000
Last reset from power-on
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: XX:XX:XX:XX:XX:XX
Part Number : XX-XXXXX-XX
PCA Assembly Number : 000-00000-00
PCA Revision Number :
PCB Serial Number : XXXXXXXX
Top Assembly Part Number : 000-00000-00
Top Assembly Serial Number : XXXXXXXX
Top Revision Number : 01
Product/Model Number : AIR-CAP702I-I-K9
Configuration register is 0xF
K9W7
Thank you a lot Mr . Leo and Mr. Sandeep for your help.
If it is an automous AP, can I join it to the vwlc or I have to convert it to lightweight mode?
You need to convert it to Lightweight to join a WLC.
Thank you a lot Mr Sandeep.
Best Regards,
and you have :
