MR45 Dark Mode
Does anyone know if the MR45 can run in Dark Mode?
cammoody
Hi @Nathanial Emmert ,
Yes, both the MR45 and MR55 can run in Run Dark mode.
@SoCalRacer, thanks for the heads-up. I just tested this myself and Run Dark does disable both the status LED and ethernet LEDs on the MR45/MR55.
I also tested and discovered that the "Blink LEDs" tool overrides Run Dark mode.
I updated the Run Dark Mode documentation to reflect this.
Cheers!
Cameron Moody | Product Manager, Cisco Meraki
SoCalRacer
Level 9
Level 9
If you are talking AP light then yes.
If you are talking ethernet port lights, then maybe.
The below doc hasn't been updated with new Wifi 6 APs @cammoody
https://documentation.meraki.com/MR/Other_Topics/Run_Dark_Mode
cammoody
Cheers!
Thank you so much for testing this!
