MSE problem affter upgrading
stephendrkw
Level 6
Level 6
Hi all,
I upgraded MSE today from 7.2.110.0 to 7.5.102.101 using the release notes, after the upgrade I get the following error:
[root@ukgrelg-174-mse init.d]# /etc/init.d/msed start
Starting MSE Platform
Starting Apache HTTPD Server
Starting Health Monitor, Waiting to check the status.
Health Monitor successfully started
ERROR! Apache Service did not startup. Please refer to apache error log under framework logs.
Stopping MSE Platform
MSE platform shutdown complete
Flushing firewall rules: [  OK  ]
Setting chains to policy ACCEPT: filter [  OK  ]
Unloading iptables modules: [  OK  ]
apache]# tail error_log
[Thu Oct 10 15:49:44 2013] [notice] caught SIGTERM, shutting down
[Thu Oct 10 15:50:00 2013] [error] Password for slot NSS FIPS 140-2 Certificate DB is incorrect.
[Thu Oct 10 15:50:00 2013] [error] NSS initialization failed. Certificate database: /var/mse/certs/nss/.
[Thu Oct 10 15:50:00 2013] [error] SSL Library Error: -8177 The security password entered is incorrect
[Thu Oct 10 15:54:56 2013] [error] Password for slot NSS FIPS 140-2 Certificate DB is incorrect.
[Thu Oct 10 15:54:56 2013] [error] NSS initialization failed. Certificate database: /var/mse/certs/nss/.
[Thu Oct 10 15:54:56 2013] [error] SSL Library Error: -8177 The security password entered is incorrect
[Thu Oct 10 15:58:16 2013] [error] Password for slot NSS FIPS 140-2 Certificate DB is incorrect.
[Thu Oct 10 15:58:16 2013] [error] NSS initialization failed. Certificate database: /var/mse/certs/nss/.
[Thu Oct 10 15:58:16 2013] [error] SSL Library Error: -8177 The security password entered is incorrect
I've ran ]# /opt/mse/framework/bin/CertMgmt.sh  and choose "9 show certificate configuration", as I expected this command displays previous certs  before my upgrade. Why there are cert password mistmatches in the apache logs I'm not sure why.
stephendrkw
Level 6
Level 6
TAC Engineer solved the problem as below
- /etc/init.d/msed stop
Remove the certificate database
– rm –rf /var/mse/certs/nss
cd /opt/mse/framework/bin/
./installNewCertificateForFIPS.sh
Restart the MSE
- /etc/init.d/msed restart
Nice - thanks for sharing.
Thanks Stephen for sharing this useful information 5+
Thanks & Regards
Vinay Sharma
Community Manager
Thanks & Regards
pchaudhary2
Community Member
This is really Useful info...Thanks Stephen !!!!
