01-08-2009 07:57 AM - edited 07-03-2021 04:57 PM
I recently have added a second Vlan on my access point. However, it's not getting an ip.
I am VERY new to the whole Vlan stuff and to more advanced networking so i am not sure what is wrong. I am thinking maybe it is because the AP is sitting behind an unmanaged switch (a 16 port linksys)?
Can the aironet handle the multi vlan without a switch that also can be set to the vlan? If it can, how do you do it?
I have both ssid working, I can connect to both of them. The vlan #2 SSID gives me "limited or no connectivity" because the vlan itself has an ip of 0.0.0.0
can someone either confirm my switch question or tell me what i've maybe done wrong? I want to use vlan #2 to seperate our "guests" from the rest of the network and it's resources. Vlan 1 is the native and is tied to the corp network.
Thanks to anyone who responds!
01-08-2009 11:28 AM
Tanner
If you want to use multiple vlans on the link from the Aironet to the switch then that link should be configured as an 802.1q trunk. Do you know if your linksys switch supports 802.1q ?
Jon
01-08-2009 12:44 PM
Jon,
thanks for the response. I doubt that the switch supports it. I will look into it. It's a FS116 model.
