My controller seems to stop udp broadcast
I have a remote control sending
UDP packet ->
src:172.17.1.173:1065 dst:255.255.255.255:30718
But the recepter (on wire network) do not receive anything.
Both are on same subnet -> 172.17.1.160/28
We do not use any ACL
idea why?
Many thanks for your precious help.
Cheers
Gael
ankbhasi
Hi Gael,
Have you enabled broadcast on controller? Can you try "config network broadcast enable" and see if that resolves the issue.
Ankur
*Pls rate all helpfull post
Hi Gael,
Did you get solution to your problem? I have a similar case where UDP port 11050 is being blocked. The customer application uses it for license management.
regards
