Nat Problem
dmalamba
Level 2
Level 2
I have a 2611 router which I use for internet connection. I have 4 administratively up interfaces. Ian using NAT inside for the three inside interfaces and and NAT outside for the Internet connection interface. I have a pool of 4 legal ip addresses which I overload with about 100 illegal internal IP addresses. Once i permit these illegal ip addresses access I get connection to the internet. After some hours this translation no longer takes effect. I try to clear the translation and restart my internet nothing happens and the translations do not take effect. If I use 1-1 static NAT the internet commes back. So I dont know what is causing my dynamic Nat just to halt like that. My Nat configuration is as follows.
ethernet o/o
ip nat inside
ethernet o/1
ip nat inside
serial 0/1
ip nat inside
serial 0/0
ip nat outside
ip nat pool Internet_access X.X.X.80 X.X.X.83 prefix-length 24
ip nat inside source list 7 pool Internet_access overload
access-list 7 permit X.X.X.0 0.0.0.200
ssoberlik
Level 9
Level 9
Sounds like an IOS bug. Your config looks good. Check your version of IOS on Cisco's bug toolkit.
