Need to synch NTP on 2100 and 4400 Wireless LAN Controllers
LEN SNEED
I have 5 WLC's (3-2100, 2-4400) and need to synch the NTP server ip addresses on them.  I know how to do this but have a question.  Using the gui, once I apply the change to the NTP ip address and save the changes, will the WLCs need to be rebooted for them to complete synchronization?
dancampb
Level 7
Level 7
No, you don't have to reboot the controllers.  They should sync right up.
dancampb
Level 7
Level 7
Thanks for the quick response.
