New access point 9124AX not visible in wireless controller 3500
Lza1
Hi! I bought a new access point for my wireless controller because one of the old access points broke. When I plug in the new one, it doesn't show up in the controller's web interface. How do I make it appear so I can set it up?
Sisco 3504 wireless controller with software version 8.5.140.0.
Cisco C9124AXI-E Catalyst Wireless Access Point.
Enes Simnica
Hello @Lza1  The reason ur new C9124AXI-E access point isn’t showing up is because it’s not supported on ur Cisco 3504 WLC with version 8.5.140.0. The Catalyst 9100 series access points require:
  • AireOS version 8.10 or later, or
  • A 9800 series controller running IOS-XE.
What u can do though is to:
  1. Check if your 3504 can be upgraded to 8.10.x and upgrade if possible.
  2. Use a supported controller, like a Cisco 9800.
  3. Return the access point and get one compatible with AireOS 8.5, such as the 2800 or 3800 series.
Hope it helps and PEACE!
-Enes
more Cisco?!
more Gym?!
If this post solved your problem, kindly mark it as Accepted Solution. Much appreciated!
Enes Simnica
-Enes
more Cisco?!
more Gym?!
Ok, thanks for the quick and clear answer!
Mark Elsen
  - @Lza1            Ref : https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
                                        This AP model is not supported on AireOS
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
