Noob Cisco Wireless Question
asprinkem90
I just set up a Cisco 5508 WLC and a 3702 AP. The AP is in flexconnect mode. Both the link to the WLC and AP are trunks. Both are using VLAN 255 as their managment ip. Facing the AP I used "switchport trunk native vlan 255", and am able to reach it over its management ip.
My question is, how do I set up an SSID to use VLAN 100 (or any other vlan)? When I go in to my AP, under the flexconnect tab, VLAN Mappings, it shows the wlan, but says its a "Centrally switched wlan". Its grayed out to specify which vlan it is in.
JPavonM
You must configure that WLAN profile (SSID) to be locally forwarded under WLANS > WLAN id > Advanced > FlexConnect.
https://community.cisco.com/t5/wireless-mobility-documents/wireless-lan-flexconnect-configuration-example/ta-p/3112924
-Jesus
*** Please Rate Helpful Responses ***
