Not able to get DHCP IP via 2504 WLAN Controller
Amanulla Khan
I have a Cisco Wlan Controller 2504 with 1042N AP (3-nos) every thing was working fine from past 2 months. Now i am getting a issue with clients which are connected to the wireless AP, they are not able to get an dhcp IP address from the 2960 Switch (DHCP Server). The clients are getting IP address as 0.0.0.0.
This is My Configuration:
System Information
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.0.220.0
Bootloader Version............................... 1.0.16
Field Recovery Image Version..................... 1.0.0
Firmware Version................................. PIC 16.0
Build Type....................................... DATA + WPS
System Name...................................... WLAN
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 192.168.0.7
Last Reset....................................... Power on reset
System Up Time................................... 0 days 2 hrs 23 mins 22 secs
System Timezone Location.........................
Current Boot License Level....................... base
Current Boot License Type........................ Permanent
Next Boot License Level.......................... base
Switch Configuration
802.3x Flow Control Mode......................... Disable
FIPS prerequisite features....................... Disabled
secret obfuscation............................... Enabled
                                                         Strong Password Check Features:
         case-check ...........Enabled
         consecutive-check ....Enabled
         default-check .......Enabled
         username-check ......Enabled
Press Enter to continue or <ctrl-z> to abort
Network Information
RF-Network Name............................. MEC
Web Mode.................................... Disable
Secure Web Mode............................. Enable
Secure Web Mode Cipher-Option High.......... Disable
Secure Web Mode Cipher-Option SSLv2......... Enable
OCSP........................................ Disabled
OCSP responder URL..........................
Secure Shell (ssh).......................... Enable
Telnet...................................... Disable
Ethernet Multicast Forwarding............... Disable
Ethernet Broadcast Forwarding............... Disable
AP Multicast/Broadcast Mode................. Multicast   Address : 0.0.0.0
IGMP snooping............................... Disabled
IGMP timeout................................ 60 seconds
IGMP Query Interval......................... 20 seconds
User Idle Timeout........................... 300 seconds
ARP Idle Timeout............................ 300 seconds
Cisco AP Default Master..................... Disable
AP Join Priority............................ Disable
Mgmt Via Wireless Interface................. Disable
Mgmt Via Dynamic Interface.................. Disable
Please Help !!!
Use only Key Index 1.
Try creating an new SSID or may be make this SSID itself for testing with open authetication (Security None) and verify if the DHCP works.
Najaf
43 Replies 43
Stephen Rodriguez
Ok, so:
1.) is the scope exhausted on the 2960?
2.) what has changed recently?
3.) is dhcp proxy enabled or disabled?
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
-No Its working fine, the pc's which are connected to the switch they are able to get DHCP IP.
-Nothing has changed.
-i checked it in the WLAN its enabled in it (If u are asking to check in WLAN)
Please still dind got any thing to get it working...
Proxy would either be Controller > Advanced or show dhcp proxy.
So you have only the one WLAN/interface?
HTH,
Steve
HTH,
Steve
Scott Fella
You try to delete the DHCP scope and add it back? The switch might be the issue. I have seen it before.
-Scott
ok i will try by doing that... !
Tried deleting the DHCP scope on the switch and checked out still the issue is same..
Hi Amanulla,
Hope your WLC is configured as Trunk Interface, Please ensure that DHCP VLAN is allowed on the Trunk Links to the WLC and on all the path between WLC and DHCP switch.Also hope you dont have any interface which is configured on WLC with 0.0.0.0 address.
Najaf
Please rate when applicable or helpful !!!
yes it is a Trunking between the WLAN interface and to the Switch were it is connected...
I had removed the DHCP cope from the switch and configured on the router...
And rebooted the WLAN controller and NOW ! i am not getting the wifi SSID.
Please help on this !!!
Sorry,
You mean you are not able to view SSID on the wireless device? Is the SSID broadcasted? Can you get the configuration from WLC please?
Najaf
sorry, checked the broadcast SSID was uncheck and found the SSID.
But still not able to get the DHCP Ip address for the wifi clients
How to set the DHCP Server Ip address in the WLAN controller.
If i check that show dhcp proxy status i can see that the dhcp server is having the Ip address of the switch which was configured previously. but now the DHCP scope is on router and how can i change it to that ?
This may help.
Najaf
Changed to the correct DHCP IP address and rebooted the Controller also..
But still clients are not getting the DHCP IP address.. froan  the router..
Sholud the DHCP proxy should be enabled or disabled on the WLAN controller, if i am using external DHCP Server..
or
Can i enable DHCP pool in the WLAN only for the Clients who connect to the wifi..  from the IP address which are not in the router DHCP pool (Excluded Ip address).. ?
