Odd issue with client
BlakeRichardson
Meraki Community All-Star
I am trying to work out what the above device is, it was connected once and sent 1KB of traffic. The port is was reportedly connect to has an internal WAP connected to it which isn't accessible without a ladder.
The SSID associated with the VLAN the client was connected to shows no logs for that MAC and the IP address isn't correct for that SSID nor a IP range that we even use.
I'm at a loss as to what this device is.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Brash
That's an interesting one.
Finger in the air type of guess:
- The user connected to Wifi (I've sometimes seen the dashboard confuse a wireless user for a wired user)
- The device is using a randomized MAC, so likely an iphone or Android phone - although any device really can do this if setup to do so.
- It's possible the device either has a static IP address set, or that's the IP address it had last used
- Lastly, no idea why you wouldn't see any logs for the association of the client.
BlakeRichardson
Thats why I am scratching my head with this one. I am assuming the device has a static IP set however it's not a range we use.
I'm at a loss.
CiscoAl
Community Member
The fact that that MAC comes back with nothing in the MAC Vendor OUI lookup normally means its a randomly generated one, probably like Brash has said below a mobile device and the dashboard has confused wireless with wired
