OEAP Remote LAN & MAC Filtering
i.va
Level 5
Level 5
I am currently trying to set up the Remote LAN feature with MAC Filtering with WLC & ISE. I want to use Central Web Authentication, but the client connected to the wired port 4 of the OEAP does not get redirected. On the WLC I see the correct web redirect URL and ACL being applied (client details), but the redirect on the client itself is not taking place. The RADIUS NAC state of the wired client is also shown as "RUN" instead of the expected "CENTRAL_WEBAUTH_REQD". No anchoring is configured for the Remote LAN, since it is not supported in this WLC software release.
Anybody have any ideas? Is this supported at all? The redirect is working fine with wireless on the OEAP.
WLC 5508 7.4.110.0
AIR-OEAP602I-E-K9
ISE 1.2.0.899
5 Replies 5
Shankar Ramanathan
Need "show run-config" output. Make a mention of the wlan.
Make sure you are using even numbered wlan on RLAN to be mapped to port 4.
Thanks for the reply! I have attached the show run-config command, but replaced some sensitive data. The WLAN ID is "44" with name "HomeOffice_RemoteLAN_Port4"
I have set it up by following the guide here (also with correct group mapping): http://www.cisco.com/en/US/products/ps11579/products_tech_note09186a0080b7f10e.shtml#t100
The general function seems fine. I get an IP address and can Ping, but there is no redirect. Hope you can help me!
You are trying web-auth redirect on rlan correct? On remote lan 44 config:
Remote LAN Configuration
Remote LAN Identifier............................ 44
Profile Name..................................... HomeOffice_RemoteLAN_Port4
Status........................................... Enabled
MAC Filtering.................................... Enabled
AAA Policy Override.............................. Enabled
Maximum number of Associated Clients............. 0
Number of Active Clients......................... 0
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 86400 seconds
User Idle Timeout................................ 300 seconds
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... XXX-XXXXXX
Webauth DHCP exclusion........................... Disabled
Interface........................................ homeoffice
Remote LAN ACL................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Enabled
PMIPv6 Mobility Type............................. none
Radius Servers
   Authentication................................ 10.65.30.220 1812
   Authentication................................ 10.65.30.221 1812
   Accounting.................................... 10.65.30.220 1813
   Accounting.................................... 10.65.30.221 1813
      Interim Update............................. Disabled
   Dynamic Interface............................. Disabled
   Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
Security
   802.1X........................................ Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
Flow Monitor Name................................ None
802.11u........................................ Disabled
MSAP Services.................................. Disabled
Yes that is correct, but I want to do MAC Filtering and redirect to ISE, and not use the local WLC Web Auth. Thats why the option is disabled. I also have this configured for WLAN ID 20, which is redirecting fine
I now have a tac case open on this issue.
Glad you opened a TAC case on this. Not sure if i understood the problem description correct here. If you are trying for a RADIUS NAC solution on OEAP, this is not a supported feature on RLAN.
