Office Extend and Guest WLAN Setup
M. Wisely
Level 4
Level 4
We're looking at deploying both office extend and also a guest wlan. Both would require a WLC in the DMZ.
My question is can one 5508 WLC be both a guest anchor and have office extend APs on it at the same time?
George Stefanick
Welcome,
Yes, a 5508 in the DMZ can act as both a anchor and officeextends solution. Very good cost effective solution whereby allowing you to use 1 WLC to do 2 functions.
I hope this helps. If this answered your question please kindly support the rating system.
George Stefanick
Welcome,
Thanks George, exactly the answer I was hoping for.
