Omnipeek and Cisco AP
Victor Fabian
Im trying to obtain data using an AP in sniffer and that data i would like to be send to remote PC using onmipeek .
i follow their instructions on the website but it dosn't work .
Any suggestion.
Thank you
Vic
dancampb
Level 7
Level 7
To use Omnipeek you have to get some remote plugins from Wild Packets. You might want to make sure you have the right version.
Also make sure you disable IP-MAC address binding on the controller. This is a requirement.
There are multiple sniffers that will work with an AP in sniffer mode. I've had the easiest time setting up Wireshark, but all of the sniffers listed have been tested.
http://www.cisco.com/en/US/docs/wireless/controller/6.0/configuration/guide/c60err.html#wp1042843
