Packet capture on AP1832i from wlc5520 dashboard client
EvgenyG
Hi team!
I've found odd thing....)
tech specs:
wlc5520 and wlc 5508 (code 8.2.170.0 both)
AP1040N and AP1832i
when tring make a packet capture from client connected to 1040N....i can see file creating on my FTP server and everything run like a charm...
But...this does not work on 1832i AP in LAP mode....even triyed from CLI.
tried to search for help on community, and seems that only me faced up with this issue...
(Cisco Controller) >config ap packet-dump start 8c:70:5a:6a:81:90
Client Mac Address............................... 8c:70:5a:6a:81:90
FTP Server IP.................................... 10.1.63.30
FTP Server Path.................................. /
FTP Server Username.............................. admin
Buffer Size for Capture.......................... 2048 KB
Packet Capture Time.............................. 2 Minutes
Packet Truncate Length........................... Unspecified
Packet Capture Classifier........................ 802.11 Management
Packet Capture Classifier........................ 802.11 Data
Packet Capture Classifier........................ 802.11 Control
Packet Capture Classifier........................ Dot1x
Packet Capture Classifier........................ ARP
Packet Capture Classifier........................ IAPP
Packet Capture Classifier........................ IP
Packet Capture Classifier........................ UDP
Packet Capture Classifier........................ TCP
Packet Capture Classifier........................ 802.11 Multicast
Packet Capture Classifier........................ 802.11 Broadcast
Are you sure you want to start capture ? (y/N) y
Yes , we  Just tried it with 3802 COS AP - fails to capture . Thanks for the sharing. Thought  we were missing something -this helps.
