PEAP MSCHAP V2 - Machine authentication not working
colmgrier
Level 4
Level 4
I have successfully got users to connect to the WLAN using PEAP-mschapv2 (no CA certificate on laptop) but I cannot get machine authentication to work.
At the moment I can get all users with diallin tab ticked to connect to the WLAN from a domain member laptop and a non member laptop. I would like to implement machine authentication so that only domain laptops will allow users to connect to the WLAN using PEAP-mschapv2.
Objective:
Allow domain user (dialin tab ticked) connected to the Wlan using a domain laptop or pc.
Please advise.
amritpatek
Level 11
Level 11
For the configuration setting for for PEAP (EAP-MSCHAP v2) Authentication follow the configuration guide http://www.cisco.com/en/US/docs/wireless/technology/peap/technical/reference/PEAP_D.html#wp1008130
For all laptop and tablet clients to authenticate using the machine credential, you need to input the below registration keys on Client/Supplicant,
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\EAPOL\Parameters\General\Global]
• SupplicantMode =dword:00000003
• AuthMode =dword:00000002
Krishan
Convergis
