Point to point with repeater
FreddyLoi
Hi All
I have a question on which i cannot find an solution.
We need to build a wirelss P2P connection with no line of sight.
But we have some difficulties configuring the repeater, or at least
the two endpoint don't see each other.
Unfortunatly I can't provide any running config's, but if anyone has a suggestion.
Please let me know.
Nicolas Darchis
A repeater connection with no line of sight doesn't sound good. What is the distance between the bridges ? Are there walls in between ?
Can you take a client and walk to the repeater position and see if you can get a signal from the root AP ?
Nicolas
The distance between the access points is:
Aironet -------- 400 meters ------------- REPEATER -------------- 50 meters ----------- Aironet
There are no walls in between.
400 is a lot for normal AP. What AP model is it and what antenna model do you have on it ? (on the aironet on the left of your diagram)
I'm not a the side right know, but I just heard they got itsorted
out.
We configured it as Non-root--Root---Non-root bridge.
Kind regards
