Point to Point with VLANs on 1242 only for wired how to hide SSID
gene.uhl
Have two 1242's that I believe I configured properly as they are passing traffic and I have an IP phone working.   The setup is as follows:
PC/Phone--->3750 Switch ---->non-root ap  ////////\\\\\\\\\\\ root ap <-------3560 switch <-------------Main Network
Has a data vlan (VLAN 10) and a voice vlan (VLAN 20)
Sub interfaces are dot110.10 and dot110.20 along with fastethernet 0.10  and 0.20 respectively.   I have two static IP's that belong to the data vlan's configured on the virtual interface for each AP.
The issue I am having is you can see the SSID.  I will ONLY have hard wired PC's and Phones connected to the 3750 switch.  No wireless clients at all.  Is there a way to stop the SSID broadcasts?  I can insert the configs if you would like.
Gene
Leo,
I think Gene wnats to know how to not broadcast the SSID
So just issue: no guest-mode
-Scott
Leo Laohoo
dot11 ssid YOUR_SSID
mbssid guest-mode
interface Dot11Radio0
mbssid
interface Dot11Radio1
mbssid
Leo,
-Scott
