Portnox
dwash
Community Member
Hi there,
I'm looking into various NACs to purchase. The default ISE & Clearpass seems way too expensive to purchase and maintain on top of Meraki Licensing. I stumbled across Portnox (never heard of it before). Is anyone else using it with their Meraki environment?
mdcole
Level 2
Level 2
I am using it in my environment. It works pretty well. Their tech support has been very responsive and great to deal with. I don't know anything about the cost so I can't comment on that part of the product.
inderdeepsingh1
Level 11
Level 11
@dwash : So you are good to go as @mdcole already using the same without any issue.
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
karam.nashwan
Visitor
I'm looking for Portnox, have you tried it?
Any Recommendations !
