Power cord for light pole installation
marstoyanoff
Hi Team,
Anyone used the following part for outdoor mesh AP power feed:
40-ft (12.2-m) power cord (AIR-CORD-R3P-40NA=) for light pole installations in the US and Canada.
I wonder what happens when the lights turn off?
Thank for you input in advance.
Marty
Scott Fella
I have... What happens when the light turns off, well that depends if your using the same circuit or not. Typically you have a separate circuit that is always on or else, well when the lights goes off, so does the AP.
-Scott
Abhishek Abhishek
Hello Marty,
As per your query i can suggest you the following solution-
When the light goes off the AP will stop functioning and will go down because it needs power to work.
Hope this will help you.
