Prevent Access Points from authenticating with my WLC?
abrrymnvette
I have a WLC 2112 and currently if you plug in a Cisco access point, it will connect to the controller and download the config. I don't like this and want to allow only the AP's that I specify. Anyone could just walk into one of our buildings and plug in an AP and get our entire wireless config. Is there a way in the WLC 2112 to only allow the AP's that I specify to be connected to the controller?
16 Replies 16
George Stefanick
Yup, the easiest way go SECURITY->>AP POLICES (left hand side menu). Check box
Authorize MIC APs against auth-list or AAA and add the wired mac address of each AP you want to connect.
DONE
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
If you want to get fancy you can leverage a AAA server and use certificates on the AP with LSC.
Thanks, that is what I was after.
Cool .. Thanks for supporting the rating system!
I'd put your production SSID outside AP Groups 1 to 16.  Put all your SSID with index 17 and more.
This way, if someone tries to put their own AP in, the AP will not broadcast any SSID.
Nice trick, Leo!
The issue with this ap group trick is that the ap would still join the WLC, pull code, and take up a license.
ap group is good for hiding ssid from the broadcast list and have a legit use. I do this with our offnet WLAN.
Nice trick, Leo!
Florin,
If you plan to do this, make sure you tell the rest of the team.  Happened to one of my colleague when I was on leave.  They deployed >20 APs and none of them were broadcasting anything.  It took them hours to realize I shuffled all the SSID index to 17 and above.  Me bad.
When you're saying SSID index you reffer to WLANs->WLANs-->WLAN ID?
Correct .. WLAN index 1 - 16 will automatically be broadcasted from the said. Making a WLAN index 17 Allows you to shape with ap groups what wlans get broadcasted from an ap ..
That's right.  Index or WLAN ID #1 to 16 goes to the "default-group" AP groups.
Make sure you have no SSIDs configured in this range.  Start with 17 and work your way up.
For a WLAN already in use can I rename ID 10 with 18?
Nope, you have to delete it & recreate with new ID
Unfortunately no, Florin.  You'll need to delete and create a new one.
