Problem blocking AP
ccieexpertadmin
Frequent Visitor
Frequent Visitor
hello
I have a block unknown source is found, occasionally, a few access points This block requires us to reset the AP via the remote controller. I have the following messages displayed at our WLC.
Invalid addr orphan : ipv6_net.c:765 Invalid ipv6 address ::, failed to do data gleaning
can you help me
Sandeep Choudhary
Disable IPv6 and check it again:
config ipv6 disable
Dont forget to rate helpful posts
abwahid
Level 9
Level 9
It is due to the IPv6 enabled, disable the IPv6 and check logs, This error would be disappear from WLC.
Abhishek Abhishek
You need to disable IPv6 with command config ipv6 disable.
Abha Jha
Workaround :
The message shows that the WLC is receiving IPv6 packets having source address of
::(Unspecified Address).
There are some workarounds:
 - Disconnect the client.
 - Disable IPv6 on the client.
 - Change logging level to critical on the WLC.
 - Disable IPv6 on WLC by "config ipv6 disable" command.
Solution :
CSCug51714 is raised to remove the message.
Upgrading 007.006(100.000) is a solution.
