problem redirecting Https
ccieexpertadmin
Frequent Visitor
Frequent Visitor
Hi Everyone ,
thank you to help me i have upgrade my cisco wlc 5500 from 6.0.196 to version 8.0 to prevent problem the redirecting to HTTPS ,
but the problem still persist ,can every body help
Best regardless
7 Replies 7
Ryan S
Level 2
Level 2
I'm not entirely sure what you're asking. Are you talking about the WLC not redirecting to the webauth page if the homepage is a secure page?
Make sure HTTPS redirect is turned on.
Management>HTTP-HTTPS>HTTPS Redirection>Enabled
Raphael
Frequent Visitor
Frequent Visitor
hello ryan
is the feature working for you? (redirect to web auth page when using a https site like https://www.google.com which is quite common)
I heard that there are some problems but haven't had the time to test it in our lab so far...
so any feedback is appreciated 🙂
Running code 8.0.100.0 https redirect is working great for me.
It was a feature never supported, not really a bug, but a bug ID was issued to it.
I blogged about it here..
http://www.my80211.com/home/2012/7/23/web-auth-redirect-doesnt-work-when-client-uses-a-https-url-c.html
8.0 is running in the lab and HTTPS is working.
Raphael
Frequent Visitor
Frequent Visitor
Thank you for sharing 🙂
With what browser did you test that?
What was the HTTPS site that you were surfing to? Was is an internal homepage with an internal certificate (own CA) or a publicly available site like google.com?
I've confirmed it works with Firefox, IE, and Chrome using internal and external websites. I've not yet come across a browser or site that it doesn't work with. https://www.google.com works fine.
This is a known bug.
https://tools.cisco.com/bugsearch/bug/%20CSCar04580
As ryanswinney99 pointed out, it is resolved in 8.0 code release.
EDIT:
I'm sorry, I missed that you went from 6.0 to 8.0 code release. What controller model are you running? That is a large jump in code.
Can you do the following commands?
>show sysinfo
>show inventory
Just looking for the PID and Product Version
