Problem share folder WLC and pc macbookpro
alfredoelias
Community Member
I am doing a migration from my wireless network in the old network in the PC MacBookPro I can see shared files on the network. But when I connect to the SSID configured on the WLC and I can not see shared files on the network. I have no ACL configured on the SSID.
Scott Fella
Is the pc and MacBook on the same vlan? The issue might be because of the bonjour services required. It should work if both devices are on the same vlan.
-Scott
Nicholas Darrow
Bonjour is a non-routabe multicast based service. A trick I use sometimes is to configure the WLAN to be in hreap mode if the ap is located locally to the target bonjour device.if your running in local mode, make sure they are on the same vlan and global multicast is enabled.
