Problem to connect directly to CISCO AP 1850
BenjaminLucas
I would like to know how to connect directly from my PC to Access point and set to static IP? My plan is to configured this access point as stand alone devices. Currently radio AP is disable so I cant connect directly through CiscoAirProvision SSID wireless.
Sandeep Choudhary
Best way is to connect via console and change the Mgmt IP address of the AP.
by using the command:
config interface address management <ip-addr> <ip-netmask> <gateway>
Dont forget to rate helpful posts
