problem trunk between a ap110 and a 3524 xl ou 2950 G
roger.le-verge
hello
the radio client (aeronet 340 pcmcia adpter) can't get dhcp ip address from the vlan server ,the trunk is configured on 3524xl and the radio client is on good bridge group ,and the interface etherne is listening the the same bridge group .
can you help me ?
roger.le-verge
ok ,the problem is resolved ,th wep key on the ssid must me the same on all the vlan for the dhcp et other broadcast ..
