Problem Wireless in Router 1812
patgeo1984
Hi guys
I nedd help. Im having a very serious problem on my wireless connection, My laptops could connect when configured, after 2 weeks of laptops can not connect, the only solution is to restart the Router.
currenty im running a c181x-adventerprisek9-mz.124-15.XY3.bin
Hope anyone can help me.
Leo Laohoo
Sounds like an IOS bug. Have you tried upgrading?
Lucien Avramov
Level 10
Level 10
You may be hitting CSCsb90481 Bad enque and Traceback when ping with packets > 1445 bytes
If you are running a newer code than 12.4(05.13)T which you obviously do, then you may be hitting a regression of this bug or a similar one, and you should contact TAC to get this properly analyzed and fixed.
This is a crash involving a traceback and TAC should be contacted, to find the proper root cause. Else you can try other versions, I dont find anything for 12.4-15.XY3.
