10-19-2003 01:31 AM - edited 07-04-2021 09:05 AM
hello,
i have a problem with my card, i have it on a Dell 5100 (laptop) first:
The card does not auto fall back when the range is far, it always stays connected at 11mbps, so that makes the range so weak. i have tried every possible configuration, but the card still isnt falling back.
second
after i installed the ACU and drivers, the windows welcome screen will not appear anymore, i have to log on the other way, when i try to change that it says:
A recently installed program has disabled the welcome screen and fast user switching, to restore these features, you must uninstall the program, the following files may help you identify the program that made the change:
cswGina.dll
any fix for that?
thanks for any help.
10-22-2003 12:00 PM
The first issue is a bug with ID CSCdy71096.
11-12-2003 07:25 AM
Forwarded:
ghess - Technical Analyst, SUPERVALU
Oct 27, 2003, 10:28am PST
Try this:
Missing cswgina.dll File After Removing or Upgrading to ACU Version 4.14.001
After removing or upgrading ACU to version 4.14.001, the cswgina.dll file can become missing if you respond incorrectly to a message indicating that a file is locked (CSCdt42742). (The appropriate response is to click Reboot.) If you respond incorrectly, a message appears just before the Windows logon screen opens indicating that you are missing a file called cswgina.dll and to see your system administrator to retrieve it.
To work around this problem, boot to a DOS prompt. Then copy the msgina.dll file in the WinNT/System32 directory over to a file named cswgina.dll.
