Problem with AP join on 3850
steven.vandyk
We are doing a POC with 3850 as MA+MC.
When the AP is in the wireless management VLAN, there is no issue, the AP joins the controller.
However we want another VLAN to be used for the APs.
Following errors on the console:
*Sep 23 11:55:00.423: *spamApTask0: 2 wcm:  %CAPWAP-3-DISC_WIRELESS_INTERFACE_ERR1: Unable to process discovery request from AP 5478.1a70.8bd0 , VLAN (30) scrIp (172.24.100.141) dstIp(255.255.255.255), could not get wireless interface belonging to this network
Last join error summary
  Type of error that occurred last                        : Lwapp discovery request rejected
  Reason for error that occurred last                     : Missing AP Manager interface
Why is he complaining about a AP-manager? This does not excist on 3850 correct?
Relevant config:
interface GigabitEthernet2/0/1
description "AP"
switchport access vlan 30
switchport mode access
switchport nonegotiate
carrier-delay msec 0
spanning-tree portfast
interface Vlan30
description AP
ip address 172.24.100.137 255.255.255.248
interface Vlan50
description Mgmt
ip address 172.24.100.169 255.255.255.248
wireless mobility controller
wireless management interface Vlan50
ip dhcp pool AP
network 172.24.100.136 255.255.255.248
default-router 172.24.100.137
dns-server 8.8.8.8
option 43 hex f104.ac18.64a9
Any ideas?
Greetings
Steven
Scott Fella
From what I know, if your AP is terminated to a 3850 running as an MC, it has to be on the management vlan.  You can change the ap manager vlan if you want the AP's to terminate on a different vlan.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Well in the config guide:
Note
: The APs need to be connected to access mode switchports in the same VLAN!
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a0080c16223.shtml
Scott
-Scott
Yes, APs need to be on the same vlan where you configure the wireless management on 3850.
