Problem with AP1200 Web admin authentication on Cisco Secure
zadmin
Community Member
I have defined a Radius Authentication for administrators logging on the AP1200 Web interface.
I can see a successfull authentication on the Cisco Secure and if I trace the packet coming back from the Cisco Secure, I can see a 'Radius Access Accept'.
Unfortunately the AP1200 does not interpretate this info correctly and the administrator still get a login window. No logs are present on the AP1200.
The versions are:
CiscoSecure ACS v2.6 for Windows 2000/NT
Release 2.6(3) Build 2
AP1200 version 12.02T (the last one non-IOS available)
In the 'Radius Access Accept' packet coming back from the Cisco Secure I can see an AV pairs equal to 255.255.255.255. I think this should be the IP address of the AP1200 instead ?
ndoshi
Hi ,
Have you defined Cisco AV Pair for this users ?
Using RADIUS, You need to use cisco AV-Pair attribute for admin users with following syntex
aironet:admin-capability=write+ident+admin+firmware
Here is the procedure for the admin user you to define the Cisco AV pair Attributes .
a) On acs select the interface configuration and go to the advance option ,
selct "per-user Tacacs/ radius attribute " click on submit .
b)On ACS , Select network configuration ,
1) check if you have configuration >> Radio ( IOS /PIX available ) on the ACS
if not add NAS type Radius IOS/PIX , note that this needed for IOS / PIX attribute
2) After adding IOS/PIX device , select interface configuration >>Radius ( IOS / PIX )
Enable [026/009/001] "cisco av-pair" option , again make sure that you enable
at user and group level click on submit
3) Add a user ( User setup >> ADD/EDIT ) to restrict administrator access control
1) enable and configure cisco 09\001 cisco av-pair using
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo_350/accsspts/ap350scg/ap350ch8.htm#1073082
zadmin
Community Member
Thanks a lot, this solve my problem !
