Problem with AP1231G and WPA/PSK
adventurer
Hi, I'm testing a AP1231G firmware 12.3(8)JA2 with 2 SSID.
SSID1: WPA/PSK (TKIP)
SSID2: WPA/Enterprise (AES)
After booting up the AP, i use a notebook to connect to SSID1. Then use another notebook to try connect to SSID2. But no other notebook is able to connect to SSID2. Nothing shows up in the log.
Then i reverse the test. After the AP boots up, i use a notebook to connect to SSID2, then another notebook to connect to SSID1. It works.
So i'm not sure why it works one way but not the other.
Am i looking at an IOS bug ?
Regards.
adventurer
The problems seems to be resolved by upgrading the AP to 12.3(8)JEA
Probably a compatibility issue between 12.3(8)JA2 and Intel Proset/wireless 10.5.0.0
Case closed.
