Problem with certificate authentication at wlc 4402
trainee02
we have a problem to get a connection from the client to the WLC.
we  are using Cisco Aironet 1130 AG and a Cisco 4402 WLC in our network. The certificate service is installed on a Windows 2008 R2 server. We use a standalone Root CA with a Enterprise Sub CA hierarchy. Issueing certificates to clients works fine. The vendor and ca certificates are installed on the WLC and the user have his user certificate. During implementation we used following document: "http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a008093f1b9.shtml#wlc". Instead of Anonymous Bind, we use a service user to read in AD (works fine, too).
We use the Intel/PRO wireless utility on our Testclient and configured it for EAP-FAST and TLS. We can select the installed certificate in the utility, but when we try to connect, the utility throw the message: "Authentication failed due to an invalid certificate".
We´ve logged the WLC and thats a part of the logfile (i´ve greyed out all enterprise data):
*EAP Framework: Jan 18 12:08:21.921: EAP-AUTH-EVENT: Waiting for asynchronous reply from LL
*LDAP DB Task 1: Jan 18 12:08:21.921: ldapTask [1] received msg 'REQUEST' (2) in state 'IDLE' (1)
*LDAP DB Task 1: Jan 18 12:08:21.922: LDAP server 1 changed state to INIT
*LDAP DB Task 1: Jan 18 12:08:21.922: LDAP_OPT_REFERRALS = -1
*LDAP DB Task 1: Jan 18 12:08:21.925: LDAP_CLIENT: UID Search (...)))
*LDAP DB Task 1: Jan 18 12:08:21.926: LDAP_CLIENT: ldap_search_ext_s returns 0 85
*LDAP DB Task 1: Jan 18 12:08:21.926: LDAP_CLIENT: Returned 2 msgs including 0 references
*LDAP DB Task 1: Jan 18 12:08:21.926: LDAP_CLIENT: Returned msg 1 type 0x64
*LDAP DB Task 1: Jan 18 12:08:21.926: LDAP_CLIENT: Received 1 attributes in search entry msg
*LDAP DB Task 1: Jan 18 12:08:21.927: LDAP_CLIENT: Returned msg 2 type 0x65
*LDAP DB Task 1: Jan 18 12:08:21.927: LDAP_CLIENT : No matched DN
*LDAP DB Task 1: Jan 18 12:08:21.927: LDAP_CLIENT : Check result error 0 rc 1013
*LDAP DB Task 1: Jan 18 12:08:21.927: LDAP_CLIENT: Received no referrals in search result msg
*LDAP DB Task 1: Jan 18 12:08:21.927: ldapAuthRequest [1] called lcapi_query base="..." (rc = 0 - Success)
*LDAP DB Task 1: Jan 18 12:08:21.927: LDAP ATTR> dn = CN=... (size 76)
*LDAP DB Task 1: Jan 18 12:08:21.927: Handling LDAP response Success
*LDAP DB Task 1: Jan 18 12:08:21.927: 18:3d:a2:0a:ec:bc [Response] Client requested no retries for mobile 18:3D:A2:0A:EC:BC
*LDAP DB Task 1: Jan 18 12:08:21.927: 18:3d:a2:0a:ec:bc Returning AAA Success for mobile 18:3d:a2:0a:ec:bc
*LDAP DB Task 1: Jan 18 12:08:21.927: AuthorizationResponse: 0x33a5affc
*LDAP DB Task 1: Jan 18 12:08:21.928: LOCAL_AUTH: Found context matching MAC address - 319
*LDAP DB Task 1: Jan 18 12:08:21.928: LOCAL_AUTH: (EAP:319) User credential callback invoked
*LDAP DB Task 1: Jan 18 12:08:21.928: LOCAL_AUTH: EAP Unable to find password in credentials. Skipped
*LDAP DB Task 1: Jan 18 12:08:21.928: LOCAL_AUTH: EAP Unable to find wlan in credentials. Skipped
*LDAP DB Task 1: Jan 18 12:08:21.928: Authenticated bind : Closing the binded session
*LDAP DB Task 1: Jan 18 12:08:21.928: ldapClose [1] called lcapi_close (rc = 0 - Success)
*LDAP DB Task 1: Jan 18 12:08:21.929: LDAP server 1 changed state to IDLE
*EAP Framework: Jan 18 12:08:21.930: EAP-EVENT: Received event 'EAP_LL_REPLY' on handle 0x78000041
*EAP Framework: Jan 18 12:08:21.930: EAP-AUTH-EVENT: Using credential profile name: ...(0x78000041)
*EAP Framework: Jan 18 12:08:21.930: EAP-AUTH-EVENT: Maximum EAP packet size: 1000
*EAP Framework: Jan 18 12:08:21.930: EAP-AUTH-EVENT: Sending method new context directive for EAP context 0x78000041
*EAP Framework: Jan 18 12:08:21.930: EAP-EVENT: Sending method directive 'New Context' on handle 0x78000041
*EAP Framework: Jan 18 12:08:21.930: eap_fast.c-EVENT: New context (EAP handle = 0x78000041)
*EAP Framework: Jan 18 12:08:21.931: id_manager.c-AUTH-SM: Got new ID f700000e - id_get
*EAP Framework: Jan 18 12:08:21.931: eap_fast.c-EVENT: Allocated new EAP-FAST context (handle = 0xF700000E)
*EAP Framework: Jan 18 12:08:21.931: EAP-AUTH-EVENT: Sending method data for context 0x78000041
*EAP Framework: Jan 18 12:08:21.931: EAP-EVENT: Sending method directive 'Receive Packet' on handle 0x78000041
*EAP Framework: Jan 18 12:08:21.931: eap_fast_auth.c-AUTH-EVENT: Process Response (EAP handle = 0x78000041)
*EAP Framework: Jan 18 12:08:21.931: eap_fast_auth.c-AUTH-EVENT: Received Identity
*EAP Framework: Jan 18 12:08:21.931: eap_fast_tlv.c-AUTH-EVENT: Adding PAC A-ID TLV (436973636f0000000000000000000000)
*EAP Framework: Jan 18 12:08:21.931: eap_fast_auth.c-AUTH-EVENT: Sending Start
*EAP Framework: Jan 18 12:08:21.931: eap_fast_auth.c-AUTH-SM: Changing state: Reset -> Start
*EAP Framework: Jan 18 12:08:21.931: eap_fast.c:2367: eap-fast tx packet:
*EAP Framework: Jan 18 12:08:21.931: eap_fast.c:138: Version: 1  Flags:S  Length:0x0014
*EAP Framework: Jan 18 12:08:21.931: eap_core.c:1422:     Payload:  00040010436973636F00000000000000 ...
*EAP Framework: Jan 18 12:08:21.931: eap_fast.c-TX-AUTH-PAK:
*EAP Framework: Jan 18 12:08:21.931: eap_core.c:1484: Code:REQUEST  ID:0x 0  Length:0x001a  Type:FAST
*EAP Framework: Jan 18 12:08:21.932: eap_core.c:1422:     Payload:  2100040010436973636F000000000000 ...
*EAP Framework: Jan 18 12:08:21.932: EAP-AUTH-EVENT: EAP method state: Continue
*EAP Framework: Jan 18 12:08:21.932: EAP-AUTH-EVENT: EAP method decision: Unknown
*EAP Framework: Jan 18 12:08:21.932: EAP-AUTH-EVENT: Current method = 43
*EAP Framework: Jan 18 12:08:21.932: EAP-AUTH-EVENT: Sending packet to lower layer for context 0x78000041
*EAP Framework: Jan 18 12:08:21.932: EAP-AUTH-TX-PAK:
*EAP Framework: Jan 18 12:08:21.932: eap_core.c:1484: Code:REQUEST  ID:0x 2  Length:0x001a  Type:FAST
*EAP Framework: Jan 18 12:08:21.932: EAP-EVENT: Started 'Authenticator Retransmit' timer (60) for EAP session handle 0x78000041
*EAP Framework: Jan 18 12:08:21.932: EAP-EVENT: Started EAP tick timer
*EAP Framework: Jan 18 12:08:21.932: EAP-EVENT: Sending lower layer event 'EAP_TX_PACKET' on handle 0x78000041
*EAP Framework: Jan 18 12:08:21.932: LOCAL_AUTH: Found matching context for id - 319
*EAP Framework: Jan 18 12:08:21.932: LOCAL_AUTH: (EAP:319) transmit event
*EAP Framework: Jan 18 12:08:21.932: AuthorizationResponse: 0x13c713fc
*EAP Framework: Jan 18 12:08:21.934: LOCAL_AUTH: AAA LOCAL AUTH EAP PKT AVP attribute 4f length 1a
*EAP Framework: Jan 18 12:08:21.934: LOCAL_AUTH: AAA LOCAL AUTH TX PKT DUMP code cc id 00 type 2b
*aaaQueueReader: Jan 18 12:08:22.290: LOCAL_AUTH: EAP: Received an auth request
*aaaQueueReader: Jan 18 12:08:22.290: LOCAL_AUTH: Found context matching MAC address - 319
*aaaQueueReader: Jan 18 12:08:22.290: LOCAL_AUTH: (EAP:319) Sending the Rxd EAP packet (id 2) to EAP subsys
*EAP Framework: Jan 18 12:08:22.291: EAP-EVENT: Received event 'EAP_RX_PACKET' on handle 0x78000041
*EAP Framework: Jan 18 12:08:22.291: EAP-AUTH-RX-PAK:
*EAP Framework: Jan 18 12:08:22.291: eap_core.c:1484: Code:RESPONSE  ID:0x 2  Length:0x0042  Type:FAST
*EAP Framework: Jan 18 12:08:22.291: eap_core.c:1422:     Payload:  810000003816030100330100002F0301 ...
*EAP Framework: Jan 18 12:08:22.291: EAP-EVENT: Stopping 'Authenticator Retransmit' timer for EAP session handle 0x78000041
*EAP Framework: Jan 18 12:08:22.291: EAP-AUTH-EVENT: EAP Response received by context 0x78000041
*EAP Framework: Jan 18 12:08:22.291: EAP-AUTH-EVENT: EAP Response type = Method (43)
*EAP Framework: Jan 18 12:08:22.291: EAP-AUTH-EVENT: Sending method data for context 0x78000041
*EAP Framework: Jan 18 12:08:22.292: EAP-EVENT: Sending method directive 'Receive Packet' on handle 0x78000041
*EAP Framework: Jan 18 12:08:22.292: eap_fast.c-AUTH-EVENT: Process Response, type: 0x2b
*EAP Framework: Jan 18 12:08:22.292: eap_fast_auth.c-AUTH-EVENT: Process Response (EAP handle = 0x78000041)
*EAP Framework: Jan 18 12:08:22.292: eap_fast_auth.c-RX-AUTH-PAK:
*EAP Framework: Jan 18 12:08:22.292: eap_core.c:1484: Code:RESPONSE  ID:0x 2  Length:0x0042  Type:FAST
*EAP Framework: Jan 18 12:08:22.292: eap_core.c:1422:     Payload:  810000003816030100330100002F0301 ...
*EAP Framework: Jan 18 12:08:22.292: eap_fast_auth.c-AUTH-EVENT: Received TLS record type: Handshake in state: Start
*EAP Framework: Jan 18 12:08:22.292: EAP-EVENT: Sending lower layer event 'EAP_GET_CREDENTIAL_PROFILE_FROM_PROFILE_NAME' on handle 0x78000041
*EAP Framework: Jan 18 12:08:22.292: LOCAL_AUTH: Found matching context for id - 319
*EAP Framework: Jan 18 12:08:22.292: LOCAL_AUTH: (EAP:319) Returning profile '...'
*EAP Framework: Jan 18 12:08:22.293: IOS_PKI_SHIM: [StartSession] - New session 0x335ee108 started (TP = 'vendor')
*EAP Framework: Jan 18 12:08:22.293: IOS_PKI_SHIM: [StartSession] - Trustpoint identity (cert) set to 'Vendor'
*EAP Framework: Jan 18 12:08:22.297: IOS_PKI_SHIM: [ID-CERT] Subject : ...
*EAP Framework: Jan 18 12:08:22.297: IOS_PKI_SHIM: [ID-CERT] Issuer : ...
*EAP Framework: Jan 18 12:08:22.297: IOS_PKI_SHIM: [ID-CERT] Valid from '2012 Jan 12th, 17:06:50 GMT' to '2016 Jan 11th, 17:06:50 GMT'
*EAP Framework: Jan 18 12:08:22.297: IOS_PKI_SHIM: [ID-CERT] Is not a CA cert
*EAP Framework: Jan 18 12:08:22.297: IOS_PKI_SHIM: Added cert (type 1) to chain (1 present on chain)
*EAP Framework: Jan 18 12:08:22.300: IOS_PKI_SHIM: [CA-CERT] Subject : ...
*EAP Framework: Jan 18 12:08:22.301: IOS_PKI_SHIM: [CA-CERT] Issuer : CN=...
*EAP Framework: Jan 18 12:08:22.301: IOS_PKI_SHIM: [CA-CERT] Valid from '2012 Jan 12th, 16:54:49 GMT' to '2020 Jan 12th, 17:04:49 GMT'
*EAP Framework: Jan 18 12:08:22.301: IOS_PKI_SHIM: [CA-CERT] Is a CA cert
*EAP Framework: Jan 18 12:08:22.301: IOS_PKI_SHIM: Added cert (type 2) to chain (2 present on chain)
*EAP Framework: Jan 18 12:08:22.301: IOS_PKI_SHIM: [StartSession] - Getting older style priv key
*EAP Framework: Jan 18 12:08:22.338: IOS_PKI_SHIM: Session 0x335ee108 init'd OK
*EAP Framework: Jan 18 12:08:22.338: eap_fast_auth.c-AUTH-EVENT: Local certificate found
*EAP Framework: Jan 18 12:08:22.339: eap_fast_auth.c-AUTH-EVENT: Reading Client Hello handshake
*EAP Framework: Jan 18 12:08:22.339: eap_fast.c:286: EAP-FAST-AUTH-RX-TLS-RECORD:
*EAP Framework: Jan 18 12:08:22.339: eap_fast.c:255: Content:Handshake  Version:0301  Length:0x0033
*EAP Framework: Jan 18 12:08:22.339: eap_core.c:1422:     Payload:  0100002F03014F16A8262631FC9DC042 ...
*EAP Framework: Jan 18 12:08:22.340: eap_fast.c:202: Handshake type:Client Hello  Length:0x002F
*EAP Framework: Jan 18 12:08:22.340: eap_core.c:1422:     Payload:  03014F16A8262631FC9DC042253D3E24 ...
*EAP Framework: Jan 18 12:08:22.340: eap_fast_auth.c-AUTH-EVENT: TLS_RSA_WITH_AES_128 proposed...
*EAP Framework: Jan 18 12:08:22.341: eap_fast_auth.c-AUTH-EVENT: TLS_DHE_RSA_WITH_AES_128_CBC_SHA proposed...
*EAP Framework: Jan 18 12:08:22.341: eap_fast_auth.c-AUTH-EVENT: TLS_RSA_WITH_RC4_128 proposed...
*EAP Framework: Jan 18 12:08:22.341: eap_fast_auth.c-AUTH-EVENT: TLS_DH_anon_WITH_AES_128_CBC_SHA proposed...
*EAP Framework: Jan 18 12:08:22.342: eap_fast.c-EVENT: Proposed ciphersuite(s):
*EAP Framework: Jan 18 12:08:22.342: eap_fast.c-EVENT:     TLS_RSA_WITH_AES_128_CBC_SHA
*EAP Framework: Jan 18 12:08:22.342: eap_fast.c-EVENT:     TLS_DHE_RSA_WITH_AES_128_CBC_SHA
*EAP Framework: Jan 18 12:08:22.342: eap_fast.c-EVENT:     TLS_RSA_WITH_RC4_128_SHA
*EAP Framework: Jan 18 12:08:22.343: eap_fast.c-EVENT:     TLS_DH_anon_WITH_AES_128_CBC_SHA
*EAP Framework: Jan 18 12:08:22.343: eap_fast.c-EVENT: Selected ciphersuite:
*EAP Framework: Jan 18 12:08:22.343: eap_fast.c-EVENT:     TLS_DHE_RSA_WITH_AES_128_CBC_SHA
*EAP Framework: Jan 18 12:08:22.343: eap_fast_auth.c-AUTH-EVENT: Building Provisioning Server Hello
*EAP Framework: Jan 18 12:08:22.344: eap_fast.c:286: EAP-FAST-AUTH-TX-TLS-RECORD:
*EAP Framework: Jan 18 12:08:22.344: eap_fast.c:255: Content:Handshake  Version:0301  Length:0x002A
*EAP Framework: Jan 18 12:08:22.344: eap_core.c:1422:     Payload:  0200002603015F3325EADF12E6296F91 ...
*EAP Framework: Jan 18 12:08:22.344: eap_fast.c:202: Handshake type:Server Hello  Length:0x0026
*EAP Framework: Jan 18 12:08:22.345: eap_core.c:1422:     Payload:  03015F3325EADF12E6296F91530FE67F ...
*EAP Framework: Jan 18 12:08:22.345: eap_fast.c:286: EAP-FAST-AUTH-TX-TLS-RECORD:
*EAP Framework: Jan 18 12:08:22.345: eap_fast.c:255: Content:Handshake  Version:0301  Length:0x0B54
*EAP Framework: Jan 18 12:08:22.346: eap_core.c:1422:     Payload:  0B000B50000B4D00059F3082059B3082 ...
*EAP Framework: Jan 18 12:08:22.346: eap_fast.c:202: Handshake type:Certificate  Length:0x0B50
*EAP Framework: Jan 18 12:08:22.346: eap_core.c:1422:     Payload:  000B4D00059F3082059B30820483A003 ...
*EAP Framework: Jan 18 12:08:22.347: eap_fast_crypto.c-EVENT: Starting Diffie Hellman phase 1 ...
*EAP Framework: Jan 18 12:08:22.661: eap_fast_crypto.c-EVENT: Diffie Hellman phase 1 complete
*EAP Framework: Jan 18 12:08:22.677: IOS_PKI_SHIM: PKI_SignMessage PostHashEncrypt ret SUCCESS.. op_len 128
*EAP Framework: Jan 18 12:08:22.678: eap_fast_auth.c-AUTH-EVENT: DH signature length = 128
*EAP Framework: Jan 18 12:08:22.678: eap_fast.c:286: EAP-FAST-AUTH-TX-TLS-RECORD:
*EAP Framework: Jan 18 12:08:22.678: eap_fast.c:255: Content:Handshake  Version:0301  Length:0x028D
*EAP Framework: Jan 18 12:08:22.679: eap_core.c:1422:     Payload:  0C0002890100FFFFFFFFFFFFFFFFC90F ...
*EAP Framework: Jan 18 12:08:22.679: eap_fast.c:202: Handshake type:Server Key Exchange  Length:0x0289
*EAP Framework: Jan 18 12:08:22.679: eap_core.c:1422:     Payload:  0100FFFFFFFFFFFFFFFFC90FDAA22168 ...
*EAP Framework: Jan 18 12:08:22.679: eap_fast.c:286: EAP-FAST-AUTH-TX-TLS-RECORD:
*EAP Framework: Jan 18 12:08:22.680: eap_fast.c:255: Content:Handshake  Version:0301  Length:0x000B
*EAP Framework: Jan 18 12:08:22.680: eap_core.c:1422:     Payload:  0D00000704030401020000
*EAP Framework: Jan 18 12:08:22.680: eap_fast.c:202: Handshake type:Certificate Request  Length:0x0007
*EAP Framework: Jan 18 12:08:22.680: eap_core.c:1422:     Payload:  04030401020000
*EAP Framework: Jan 18 12:08:22.681: eap_fast.c:286: EAP-FAST-AUTH-TX-TLS-RECORD:
*EAP Framework: Jan 18 12:08:22.681: eap_fast.c:255: Content:Handshake  Version:0301  Length:0x0004
*EAP Framework: Jan 18 12:08:22.681: eap_core.c:1422:     Payload:  0E000000
*EAP Framework: Jan 18 12:08:22.681: eap_fast.c:202: Handshake type:Server Done  Length:0x0000
*EAP Framework: Jan 18 12:08:22.682: eap_fast_auth.c-AUTH-EVENT: Sending Provisioning Serving Hello
*EAP Framework: Jan 18 12:08:22.682: eap_fast_auth.c-AUTH-SM: Changing state: Start -> Sent provisioning Server Hello
*EAP Framework: Jan 18 12:08:22.682: eap_fast.c-EVENT: Tx packet fragmentation required
*EAP Framework: Jan 18 12:08:22.683: eap_fast.c:2367: eap-fast tx packet:
*EAP Framework: Jan 18 12:08:22.683: eap_fast.c:138: Version: 1  Flags:LM  Length:0x03DE
*EAP Framework: Jan 18 12:08:22.683: eap_core.c:1422:     Payload:  160301002A0200002603015F3325EADF ...
*EAP Framework: Jan 18 12:08:22.684: eap_fast.c-TX-AUTH-PAK:
*EAP Framework: Jan 18 12:08:22.684: eap_core.c:1484: Code:REQUEST  ID:0x 0  Length:0x03e8  Type:FAST
*EAP Framework: Jan 18 12:08:22.684: eap_core.c:1422:     Payload:  C100000E33160301002A020000260301 ...
*EAP Framework: Jan 18 12:08:22.684: EAP-AUTH-EVENT: EAP method state: Continue
*EAP Framework: Jan 18 12:08:22.685: EAP-AUTH-EVENT: EAP method decision: Unknown
*EAP Framework: Jan 18 12:08:22.685: EAP-AUTH-EVENT: Current method = 43
*EAP Framework: Jan 18 12:08:22.685: EAP-AUTH-EVENT: Sending packet to lower layer for context 0x78000041
*EAP Framework: Jan 18 12:08:22.685: EAP-AUTH-TX-PAK:
*EAP Framework: Jan 18 12:08:22.685: eap_core.c:1484: Code:REQUEST  ID:0x 3  Length:0x03e8  Type:FAST
*EAP Framework: Jan 18 12:08:22.686: eap_core.c:1422:     Payload:  C100000E33160301002A020000260301 ...
*EAP Framework: Jan 18 12:08:22.686: EAP-EVENT: Started 'Authenticator Retransmit' timer (60) for EAP session handle 0x78000041
*EAP Framework: Jan 18 12:08:22.686: EAP-EVENT: Started EAP tick timer
*EAP Framework: Jan 18 12:08:22.686: EAP-EVENT: Sending lower layer event 'EAP_TX_PACKET' on handle 0x78000041
*EAP Framework: Jan 18 12:08:22.686: LOCAL_AUTH: Found matching context for id - 319
*EAP Framework: Jan 18 12:08:22.687: LOCAL_AUTH: (EAP:319) transmit event
*EAP Framework: Jan 18 12:08:22.687: AuthorizationResponse: 0x13c713fc
*EAP Framework: Jan 18 12:08:22.755: LOCAL_AUTH: AAA LOCAL AUTH EAP PKT AVP attribute 4f length 297
*EAP Framework: Jan 18 12:08:22.755: LOCAL_AUTH: AAA LOCAL AUTH TX PKT DUMP code cc id 00 type 2b
*aaaQueueReader: Jan 18 12:08:22.830: LOCAL_AUTH: EAP: Received an auth request
*aaaQueueReader: Jan 18 12:08:22.830: LOCAL_AUTH: Found context matching MAC address - 319
*aaaQueueReader: Jan 18 12:08:22.830: LOCAL_AUTH: (EAP:319) Sending the Rxd EAP packet (id 6) to EAP subsys
*EAP Framework: Jan 18 12:08:22.831: EAP-EVENT: Received event 'EAP_RX_PACKET' on handle 0x78000041
*EAP Framework: Jan 18 12:08:22.831: EAP-AUTH-RX-PAK:
*EAP Framework: Jan 18 12:08:22.831: eap_core.c:1484: Code:RESPONSE  ID:0x 6  Length:0x015c  Type:FAST
*EAP Framework: Jan 18 12:08:22.831: eap_core.c:1422:     Payload:  810000015216030100070B0000030000 ...
*EAP Framework: Jan 18 12:08:22.831: EAP-EVENT: Stopping 'Authenticator Retransmit' timer for EAP session handle 0x78000041
*EAP Framework: Jan 18 12:08:22.831: EAP-AUTH-EVENT: EAP Response received by context 0x78000041
*EAP Framework: Jan 18 12:08:22.832: EAP-AUTH-EVENT: EAP Response type = Method (43)
*EAP Framework: Jan 18 12:08:22.832: EAP-AUTH-EVENT: Sending method data for context 0x78000041
*EAP Framework: Jan 18 12:08:22.832: EAP-EVENT: Sending method directive 'Receive Packet' on handle 0x78000041
*EAP Framework: Jan 18 12:08:22.832: eap_fast.c-AUTH-EVENT: Process Response, type: 0x2b
*EAP Framework: Jan 18 12:08:22.832: eap_fast_auth.c-AUTH-EVENT: Process Response (EAP handle = 0x78000041)
*EAP Framework: Jan 18 12:08:22.832: eap_fast_auth.c-RX-AUTH-PAK:
*EAP Framework: Jan 18 12:08:22.832: eap_core.c:1484: Code:RESPONSE  ID:0x 6  Length:0x015c  Type:FAST
*EAP Framework: Jan 18 12:08:22.832: eap_core.c:1422:     Payload:  810000015216030100070B0000030000 ...
*EAP Framework: Jan 18 12:08:22.832: eap_fast_auth.c-AUTH-EVENT: Received TLS record type: Handshake in state: Sent provisioning Server Hello
*EAP Framework: Jan 18 12:08:22.832: eap_fast_auth.c-AUTH-EVENT: Reading Client Certificate handshake
*EAP Framework: Jan 18 12:08:22.832: eap_fast.c:286: EAP-FAST-AUTH-RX-TLS-RECORD:
*EAP Framework: Jan 18 12:08:22.832: eap_fast.c:255: Content:Handshake  Version:0301  Length:0x0007
*EAP Framework: Jan 18 12:08:22.832: eap_core.c:1422:     Payload:  0B000003000000
*EAP Framework: Jan 18 12:08:22.832: eap_fast.c:202: Handshake type:Certificate  Length:0x0003
*EAP Framework: Jan 18 12:08:22.832: eap_core.c:1422:     Payload:  000000
*EAP Framework: Jan 18 12:08:22.833: eap_fast.c-EVENT: Client Certificate handshake empty
*EAP Framework: Jan 18 12:08:22.833: eap_fast_auth.c-AUTH-EVENT: Rx'd I-ID: "EAP-FAST I-ID" from Peer Cert
*EAP Framework: Jan 18 12:08:22.833: eap_fast_auth.c-AUTH-ERROR: Required cert not provided by client
*EAP Framework: Jan 18 12:08:22.833: eap_fast.c:286: EAP-FAST-AUTH-TX-TLS-RECORD:
*EAP Framework: Jan 18 12:08:22.833: eap_fast.c:255: Content:Alert  Version:0301  Length:0x0002
*EAP Framework: Jan 18 12:08:22.833: eap_core.c:1422:     Payload:  0228
*EAP Framework: Jan 18 12:08:22.833: eap_fast_auth.c-AUTH-SM: Changing state: Sent provisioning Server Hello -> Alert
*EAP Framework: Jan 18 12:08:22.833: eap_fast.c:2367: eap-fast tx packet:
*EAP Framework: Jan 18 12:08:22.833: eap_fast.c:138: Version: 1  Flags:L  Length:0x0007
*EAP Framework: Jan 18 12:08:22.833: eap_core.c:1422:     Payload:  15030100020228
*EAP Framework: Jan 18 12:08:22.833: eap_fast.c-TX-AUTH-PAK:
*EAP Framework: Jan 18 12:08:22.833: eap_core.c:1484: Code:REQUEST  ID:0x 0  Length:0x0011  Type:FAST
*EAP Framework: Jan 18 12:08:22.833: eap_core.c:1422:     Payload:  810000000715030100020228
*EAP Framework: Jan 18 12:08:22.833: EAP-AUTH-EVENT: EAP method state: Continue
*EAP Framework: Jan 18 12:08:22.834: EAP-AUTH-EVENT: EAP method decision: Fail
*EAP Framework: Jan 18 12:08:22.834: EAP-AUTH-EVENT: Current method = 43
*EAP Framework: Jan 18 12:08:22.834: EAP-AUTH-EVENT: Sending packet to lower layer for context 0x78000041
*EAP Framework: Jan 18 12:08:22.834: EAP-AUTH-TX-PAK:
*EAP Framework: Jan 18 12:08:22.834: eap_core.c:1484: Code:REQUEST  ID:0x 7  Length:0x0011  Type:FAST
*EAP Framework: Jan 18 12:08:22.834: eap_core.c:1422:     Payload:  810000000715030100020228
*EAP Framework: Jan 18 12:08:22.834: EAP-EVENT: Started 'Authenticator Retransmit' timer (60) for EAP session handle 0x78000041
*EAP Framework: Jan 18 12:08:22.834: EAP-EVENT: Started EAP tick timer
*EAP Framework: Jan 18 12:08:22.834: EAP-EVENT: Sending lower layer event 'EAP_TX_PACKET' on handle 0x78000041
*EAP Framework: Jan 18 12:08:22.834: LOCAL_AUTH: Found matching context for id - 319
*EAP Framework: Jan 18 12:08:22.834: LOCAL_AUTH: (EAP:319) transmit event
*EAP Framework: Jan 18 12:08:22.834: AuthorizationResponse: 0x13c713fc
We think that the reason why it didn´t work, is the part:
But we aren´t sure.
Maybe anyone can help us. Many thanks in advance.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.01.18 12:08:18 =~=~=~=~=~=~=~=~=~=~=~=
debug aaa all disable                     debug aaa all enable
(Cisco Controller) >*Dot1x_NW_MsgTask_0: Jan 18 12:08:21.917: 18:3d:a2:0a:ec:bc Audit Session ID added to the mscb: 0a63081e000000994f16a825
*Dot1x_NW_MsgTask_0: Jan 18 12:08:21.917: Creating audit session ID (dot1x_aaa_eapresp_supp) and Radius Request
*aaaQueueReader: Jan 18 12:08:21.917: AuthenticationRequest: 0x30b52e90
*aaaQueueReader: Jan 18 12:08:21.917: Callback.....................................0x10b7803c
*aaaQueueReader: Jan 18 12:08:21.917: protocolType.................................0x00140001
*aaaQueueReader: Jan 18 12:08:21.917: proxyState...................................18:3D:A2:0A:EC:BC-02:00
*aaaQueueReader: Jan 18 12:08:21.917: Packet contains 16 AVPs (not shown)
*aaaQueueReader: Jan 18 12:08:21.917: 18:3d:a2:0a:ec:bc [Error] Client requested no retries for mobile 18:3D:A2:0A:EC:BC
*aaaQueueReader: Jan 18 12:08:21.918: 18:3d:a2:0a:ec:bc Returning AAA Error 'No Server' (-7) for mobile 18:3d:a2:0a:ec:bc
*aaaQueueReader: Jan 18 12:08:21.918: AuthorizationResponse: 0x3e04bd08
*aaaQueueReader: Jan 18 12:08:21.918: structureSize................................32
*aaaQueueReader: Jan 18 12:08:21.918: resultCode...................................-7
*aaaQueueReader: Jan 18 12:08:21.918: protocolUsed.................................0xffffffff
*aaaQueueReader: Jan 18 12:08:21.918: proxyState...................................18:3D:A2:0A:EC:BC-02:00
*aaaQueueReader: Jan 18 12:08:21.918: Packet contains 0 AVPs:
*aaaQueueReader: Jan 18 12:08:21.918: LOCAL_AUTH: EAP: Received an auth request
*aaaQueueReader: Jan 18 12:08:21.918: LOCAL_AUTH: Creating new context
*aaaQueueReader: Jan 18 12:08:21.918: EAP-EVENT: Received context create from lower layer (0x0000013F)
*aaaQueueReader: Jan 18 12:08:21.918: id_manager.c-AUTH-SM: Got new ID 78000041 - id_get
*aaaQueueReader: Jan 18 12:08:21.918: EAP-EVENT: Received credential profile name: "(null)" from LL
*aaaQueueReader: Jan 18 12:08:21.918: EAP-EVENT: Allocated new EAP context (handle = 0x78000041)
*aaaQueueReader: Jan 18 12:08:21.919: LOCAL_AUTH: Created new context eap session handle 78000041
*aaaQueueReader: Jan 18 12:08:21.919: LOCAL_AUTH: (EAP:319) Sending the Rxd EAP packet (id 1) to EAP subsys
*EAP Framework: Jan 18 12:08:21.919: EAP-EVENT: Received event 'EAP_RX_PACKET' on handle 0x78000041
*EAP Framework: Jan 18 12:08:21.920: EAP-AUTH-RX-PAK:
*EAP Framework: Jan 18 12:08:21.920: eap_core.c:1484: Code:RESPONSE  ID:0x 1  Length:0x002b  Type:IDENTITY
*EAP Framework: Jan 18 12:08:21.920: eap_core.c:1422:     Payload:  416E6472652E54736368656E74736368 ...
*EAP Framework: Jan 18 12:08:21.920: EAP-AUTH-EVENT: EAP Response received by context 0x78000041
*EAP Framework: Jan 18 12:08:21.920: EAP-AUTH-EVENT: EAP Response type = Identity
*EAP Framework: Jan 18 12:08:21.920: EAP-AUTH-EVENT: Received peer identity: Andre.Tschentscher@group.jenoptik.corp
*EAP Framework: Jan 18 12:08:21.920: EAP-EVENT: Sending lower layer event 'EAP_GET_CREDENTIAL_PROFILE_FROM_USERNAME' on handle 0x78000041
*EAP Framework: Jan 18 12:08:21.920: LOCAL_AUTH: Found matching context for id - 319
*EAP Framework: Jan 18 12:08:21.921: LOCAL_AUTH: (EAP) Sending user credential request username 'Andre.Tschentscher@group.jenoptik.corp' to LDAP
*aaaQueueReader: Jan 18 12:08:21.921: AuthenticationRequest: 0x33a6ae18
*aaaQueueReader: Jan 18 12:08:21.921: Callback.....................................0x10765234
*aaaQueueReader: Jan 18 12:08:21.921: protocolType.................................0x00100002
*aaaQueueReader: Jan 18 12:08:21.921: proxyState...................................18:3D:A2:0A:EC:BC-00:00
*aaaQueueReader: Jan 18 12:08:21.921: Packet contains 2 AVPs (not shown)
*LDAP DB Task 1: Jan 18 12:08:21.922: ldapInitAndBind [1] called lcapi_init (rc = 0 - Success)
*LDAP DB Task 1: Jan 18 12:08:21.925: ldapInitAndBind [1] configured Method Authenticated lcapi_bind (rc = 0 - Success)
*LDAP DB Task 1: Jan 18 12:08:21.925: LDAP server 1 changed state to CONNECTED
*LDAP DB Task 1: Jan 18 12:08:21.925: disabled LDAP_OPT_REFERRALS
*LDAP DB Task 1: Jan 18 12:08:21.925: LDAP_CLIENT: UID Search (base=DC=group,DC=jenoptik,DC=corp, pattern=(&(objectclass=Person)(userPrincipalName=Andre.Tschentscher@group.jenoptik.corp)))
*LDAP DB Task 1: Jan 18 12:08:21.927: ldapAuthRequest [1] called lcapi_query base="DC=group,DC=jenoptik,DC=corp" type="Person" attr="userPrincipalName" user="Andre.Tschentscher@group.jenoptik.corp" (rc = 0 - Success)
*LDAP DB Task 1: Jan 18 12:08:21.927: LDAP ATTR> dn = CN=Tschentscher\, Andre,OU=Users,OU=SSC,OU=JOAG,DC=group,DC=jenoptik,DC=corp (size 76)
*LDAP DB Task 1: Jan 18 12:08:21.927: structureSize................................180
*LDAP DB Task 1: Jan 18 12:08:21.927: resultCode...................................0
*LDAP DB Task 1: Jan 18 12:08:21.927: protocolUsed.................................0x00000002
*LDAP DB Task 1: Jan 18 12:08:21.927: proxyState...................................18:3D:A2:0A:EC:BC-00:00
*LDAP DB Task 1: Jan 18 12:08:21.928: Packet contains 2 AVPs:
*LDAP DB Task 1: Jan 18 12:08:21.928:     AVP[01] Unknown Attribute 0......................CN=Tschentscher\, Andre,OU=Users,OU=SSC,OU=JOAG,DC=group,DC=jenoptik,DC=corp (76 bytes)
*LDAP DB Task 1: Jan 18 12:08:21.928:     AVP[02] User-Name................................Andre.Tschentscher@group.jenoptik.corp (38 bytes)
*EAP Framework: Jan 18 12:08:21.930: EAP-AUTH-EVENT: Using credential profile name: Andre.Tschentscher@group.jenoptik.corp (0x78000041)
*EAP Framework: Jan 18 12:08:21.933: structureSize................................74
*EAP Framework: Jan 18 12:08:21.933: resultCode...................................255
*EAP Framework: Jan 18 12:08:21.933: protocolUsed.................................0x00000080
*EAP Framework: Jan 18 12:08:21.933: proxyState...................................18:3D:A2:0A:EC:BC-02:00
*EAP Framework: Jan 18 12:08:21.934: Packet contains 1 AVPs (not shown)
*EAP Framework: Jan 18 12:08:22.292: LOCAL_AUTH: (EAP:319) Returning profile 'Andre.Tschentscher@group.jenoptik.corp' (username 'Andre.Tschentscher@group.jenoptik.corp')
*EAP Framework: Jan 18 12:08:22.297: IOS_PKI_SHIM: [ID-CERT] Subject : C=DE, ST=Thuringia, L=Jena, O=Jenoptik AG, OU=Jenoptik SSC GmbH, CN=Cisco WLC 1st, MAILTO=zit-network@jenoptik.net
*EAP Framework: Jan 18 12:08:22.297: IOS_PKI_SHIM: [ID-CERT] Issuer : DC=corp, DC=jenoptik, CN=Jenoptik WLAN Certificate Authority
*EAP Framework: Jan 18 12:08:22.300: IOS_PKI_SHIM: [CA-CERT] Subject : DC=corp, DC=jenoptik, CN=Jenoptik WLAN Certificate Authority
*EAP Framework: Jan 18 12:08:22.301: IOS_PKI_SHIM: [CA-CERT] Issuer : CN=Jenoptik Certificate Authority
*EAP Framework: Jan 18 12:08:22.687: structureSize................................1048
*EAP Framework: Jan 18 12:08:22.687: resultCode...................................255
*EAP Framework: Jan 18 12:08:22.687: protocolUsed.................................0x00000080
*EAP Framework: Jan 18 12:08:22.688: proxyState...................................18:3D:A2:0A:EC:BC-02:01
*EAP Framework: Jan 18 12:08:22.688: Packet contains 1 AVPs (not shown)
*EAP Framework: Jan 18 12:08:22.688: LOCAL_AUTH: AAA LOCAL AUTH EAP PKT AVP attribute 4f length 3e8
*EAP Framework: Jan 18 12:08:22.688: LOCAL_AUTH: AAA LOCAL AUTH TX PKT DUMP code cc id 00 type 2b
*aaaQueueReader: Jan 18 12:08:22.700: LOCAL_AUTH: EAP: Received an auth request
*aaaQueueReader: Jan 18 12:08:22.701: LOCAL_AUTH: Found context matching MAC address - 319
*aaaQueueReader: Jan 18 12:08:22.701: LOCAL_AUTH: (EAP:319) Sending the Rxd EAP packet (id 3) to EAP subsys
*EAP Framework: Jan 18 12:08:22.701: EAP-EVENT: Received event 'EAP_RX_PACKET' on handle 0x78000041
*EAP Framework: Jan 18 12:08:22.701: EAP-AUTH-RX-PAK:
*EAP Framework: Jan 18 12:08:22.702: eap_core.c:1484: Code:RESPONSE  ID:0x 3  Length:0x0006  Type:FAST
*EAP Framework: Jan 18 12:08:22.702: eap_core.c:1422:     Payload:  01
*EAP Framework: Jan 18 12:08:22.702: EAP-EVENT: Stopping 'Authenticator Retransmit' timer for EAP session handle 0x78000041
*EAP Framework: Jan 18 12:08:22.703: EAP-AUTH-EVENT: EAP Response received by context 0x78000041
*EAP Framework: Jan 18 12:08:22.703: EAP-AUTH-EVENT: EAP Response type = Method (43)
*EAP Framework: Jan 18 12:08:22.703: EAP-AUTH-EVENT: Sending method data for context 0x78000041
*EAP Framework: Jan 18 12:08:22.704: EAP-EVENT: Sending method directive 'Receive Packet' on handle 0x78000041
*EAP Framework: Jan 18 12:08:22.704: eap_fast.c-AUTH-EVENT: eap_fast_rx_packet(): EAP Fast NoData (0x2b)
*EAP Framework: Jan 18 12:08:22.704: eap_fast.c:2367: eap-fast tx packet:
*EAP Framework: Jan 18 12:08:22.704: eap_fast.c:138: Version: 1  Flags:M  Length:0x03E2
*EAP Framework: Jan 18 12:08:22.705: eap_core.c:1422:     Payload:  3A2F2F2F434E3D4A656E6F7074696B25 ...
*EAP Framework: Jan 18 12:08:22.705: eap_fast.c-TX-AUTH-PAK:
*EAP Framework: Jan 18 12:08:22.705: eap_core.c:1484: Code:REQUEST  ID:0x 0  Length:0x03e8  Type:FAST
*EAP Framework: Jan 18 12:08:22.705: eap_core.c:1422:     Payload:  413A2F2F2F434E3D4A656E6F7074696B ...
*EAP Framework: Jan 18 12:08:22.706: EAP-AUTH-EVENT: EAP method state: Continue
*EAP Framework: Jan 18 12:08:22.706: EAP-AUTH-EVENT: EAP method decision: Unknown
*EAP Framework: Jan 18 12:08:22.706: EAP-AUTH-EVENT: Current method = 43
*EAP Framework: Jan 18 12:08:22.706: EAP-AUTH-EVENT: Sending packet to lower layer for context 0x78000041
*EAP Framework: Jan 18 12:08:22.707: EAP-AUTH-TX-PAK:
*EAP Framework: Jan 18 12:08:22.707: eap_core.c:1484: Code:REQUEST  ID:0x 4  Length:0x03e8  Type:FAST
*EAP Framework: Jan 18 12:08:22.707: eap_core.c:1422:     Payload:  413A2F2F2F434E3D4A656E6F7074696B ...
*EAP Framework: Jan 18 12:08:22.707: EAP-EVENT: Started 'Authenticator Retransmit' timer (60) for EAP session handle 0x78000041
*EAP Framework: Jan 18 12:08:22.708: EAP-EVENT: Started EAP tick timer
*EAP Framework: Jan 18 12:08:22.708: EAP-EVENT: Sending lower layer event 'EAP_TX_PACKET' on handle 0x78000041
*EAP Framework: Jan 18 12:08:22.708: LOCAL_AUTH: Found matching context for id - 319
*EAP Framework: Jan 18 12:08:22.708: LOCAL_AUTH: (EAP:319) transmit event
*EAP Framework: Jan 18 12:08:22.709: AuthorizationResponse: 0x13c713fc
*EAP Framework: Jan 18 12:08:22.709: structureSize................................1048
*EAP Framework: Jan 18 12:08:22.709: resultCode...................................255
*EAP Framework: Jan 18 12:08:22.709: protocolUsed.................................0x00000080
*EAP Framework: Jan 18 12:08:22.710: proxyState...................................18:3D:A2:0A:EC:BC-02:02
*EAP Framework: Jan 18 12:08:22.710: Packet contains 1 AVPs (not shown)
*EAP Framework: Jan 18 12:08:22.710: LOCAL_AUTH: AAA LOCAL AUTH EAP PKT AVP attribute 4f length 3e8
*EAP Framework: Jan 18 12:08:22.711: LOCAL_AUTH: AAA LOCAL AUTH TX PKT DUMP code cc id 00 type 2b
*aaaQueueReader: Jan 18 12:08:22.723: LOCAL_AUTH: EAP: Received an auth request
*aaaQueueReader: Jan 18 12:08:22.723: LOCAL_AUTH: Found context matching MAC address - 319
*aaaQueueReader: Jan 18 12:08:22.724: LOCAL_AUTH: (EAP:319) Sending the Rxd EAP packet (id 4) to EAP subsys
*EAP Framework: Jan 18 12:08:22.724: EAP-EVENT: Received event 'EAP_RX_PACKET' on handle 0x78000041
*EAP Framework: Jan 18 12:08:22.725: EAP-AUTH-RX-PAK:
*EAP Framework: Jan 18 12:08:22.725: eap_core.c:1484: Code:RESPONSE  ID:0x 4  Length:0x0006  Type:FAST
*EAP Framework: Jan 18 12:08:22.725: eap_core.c:1422:     Payload:  01
*EAP Framework: Jan 18 12:08:22.725: EAP-EVENT: Stopping 'Authenticator Retransmit' timer for EAP session handle 0x78000041
*EAP Framework: Jan 18 12:08:22.726: EAP-AUTH-EVENT: EAP Response received by context 0x78000041
*EAP Framework: Jan 18 12:08:22.726: EAP-AUTH-EVENT: EAP Response type = Method (43)
*EAP Framework: Jan 18 12:08:22.726: EAP-AUTH-EVENT: Sending method data for context 0x78000041
*EAP Framework: Jan 18 12:08:22.726: EAP-EVENT: Sending method directive 'Receive Packet' on handle 0x78000041
*EAP Framework: Jan 18 12:08:22.727: eap_fast.c-AUTH-EVENT: eap_fast_rx_packet(): EAP Fast NoData (0x2b)
*EAP Framework: Jan 18 12:08:22.727: eap_fast.c:2367: eap-fast tx packet:
*EAP Framework: Jan 18 12:08:22.727: eap_fast.c:138: Version: 1  Flags:M  Length:0x03E2
*EAP Framework: Jan 18 12:08:22.728: eap_core.c:1422:     Payload:  BD84CC4BF49A766267DA94429BEBE087 ...
*EAP Framework: Jan 18 12:08:22.728: eap_fast.c-TX-AUTH-PAK:
*EAP Framework: Jan 18 12:08:22.728: eap_core.c:1484: Code:REQUEST  ID:0x 0  Length:0x03e8  Type:FAST
*EAP Framework: Jan 18 12:08:22.728: eap_core.c:1422:     Payload:  41BD84CC4BF49A766267DA94429BEBE0 ...
*EAP Framework: Jan 18 12:08:22.729: EAP-AUTH-EVENT: EAP method state: Continue
*EAP Framework: Jan 18 12:08:22.729: EAP-AUTH-EVENT: EAP method decision: Unknown
*EAP Framework: Jan 18 12:08:22.729: EAP-AUTH-EVENT: Current method = 43
*EAP Framework: Jan 18 12:08:22.729: EAP-AUTH-EVENT: Sending packet to lower layer for context 0x78000041
*EAP Framework: Jan 18 12:08:22.730: EAP-AUTH-TX-PAK:
*EAP Framework: Jan 18 12:08:22.730: eap_core.c:1484: Code:REQUEST  ID:0x 5  Length:0x03e8  Type:FAST
*EAP Framework: Jan 18 12:08:22.730: eap_core.c:1422:     Payload:  41BD84CC4BF49A766267DA94429BEBE0 ...
*EAP Framework: Jan 18 12:08:22.731: EAP-EVENT: Started 'Authenticator Retransmit' timer (60) for EAP session handle 0x78000041
*EAP Framework: Jan 18 12:08:22.731: EAP-EVENT: Started EAP tick timer
*EAP Framework: Jan 18 12:08:22.731: EAP-EVENT: Sending lower layer event 'EAP_TX_PACKET' on handle 0x78000041
*EAP Framework: Jan 18 12:08:22.731: LOCAL_AUTH: Found matching context for id - 319
*EAP Framework: Jan 18 12:08:22.732: LOCAL_AUTH: (EAP:319) transmit event
*EAP Framework: Jan 18 12:08:22.732: AuthorizationResponse: 0x13c713fc
*EAP Framework: Jan 18 12:08:22.732: structureSize................................1048
*EAP Framework: Jan 18 12:08:22.732: resultCode...................................255
*EAP Framework: Jan 18 12:08:22.733: protocolUsed.................................0x00000080
*EAP Framework: Jan 18 12:08:22.733: proxyState...................................18:3D:A2:0A:EC:BC-02:03
*EAP Framework: Jan 18 12:08:22.733: Packet contains 1 AVPs (not shown)
*EAP Framework: Jan 18 12:08:22.734: LOCAL_AUTH: AAA LOCAL AUTH EAP PKT AVP attribute 4f length 3e8
*EAP Framework: Jan 18 12:08:22.734: LOCAL_AUTH: AAA LOCAL AUTH TX PKT DUMP code cc id 00 type 2b
*aaaQueueReader: Jan 18 12:08:22.746: LOCAL_AUTH: EAP: Received an auth request
*aaaQueueReader: Jan 18 12:08:22.747: LOCAL_AUTH: Found context matching MAC address - 319
*aaaQueueReader: Jan 18 12:08:22.747: LOCAL_AUTH: (EAP:319) Sending the Rxd EAP packet (id 5) to EAP subsys
*EAP Framework: Jan 18 12:08:22.747: EAP-EVENT: Received event 'EAP_RX_PACKET' on handle 0x78000041
*EAP Framework: Jan 18 12:08:22.747: EAP-AUTH-RX-PAK:
*EAP Framework: Jan 18 12:08:22.748: eap_core.c:1484: Code:RESPONSE  ID:0x 5  Length:0x0006  Type:FAST
*EAP Framework: Jan 18 12:08:22.748: eap_core.c:1422:     Payload:  01
*EAP Framework: Jan 18 12:08:22.748: EAP-EVENT: Stopping 'Authenticator Retransmit' timer for EAP session handle 0x78000041
*EAP Framework: Jan 18 12:08:22.749: EAP-AUTH-EVENT: EAP Response received by context 0x78000041
*EAP Framework: Jan 18 12:08:22.749: EAP-AUTH-EVENT: EAP Response type = Method (43)
*EAP Framework: Jan 18 12:08:22.749: EAP-AUTH-EVENT: Sending method data for context 0x78000041
*EAP Framework: Jan 18 12:08:22.750: EAP-EVENT: Sending method directive 'Receive Packet' on handle 0x78000041
*EAP Framework: Jan 18 12:08:22.750: eap_fast.c-AUTH-EVENT: eap_fast_rx_packet(): EAP Fast NoData (0x2b)
*EAP Framework: Jan 18 12:08:22.750: eap_fast.c:2367: eap-fast tx packet:
*EAP Framework: Jan 18 12:08:22.750: eap_fast.c:138: Version: 1  Flags:  Length:0x0291
*EAP Framework: Jan 18 12:08:22.751: eap_core.c:1422:     Payload:  34C4C6628B80DC1CD129024E088A67CC ...
*EAP Framework: Jan 18 12:08:22.751: eap_fast.c-TX-AUTH-PAK:
*EAP Framework: Jan 18 12:08:22.751: eap_core.c:1484: Code:REQUEST  ID:0x 0  Length:0x0297  Type:FAST
*EAP Framework: Jan 18 12:08:22.751: eap_core.c:1422:     Payload:  0134C4C6628B80DC1CD129024E088A67 ...
*EAP Framework: Jan 18 12:08:22.751: EAP-AUTH-EVENT: EAP method state: Continue
*EAP Framework: Jan 18 12:08:22.751: EAP-AUTH-EVENT: EAP method decision: Unknown
*EAP Framework: Jan 18 12:08:22.752: EAP-AUTH-EVENT: Current method = 43
*EAP Framework: Jan 18 12:08:22.752: EAP-AUTH-EVENT: Sending packet to lower layer for context 0x78000041
*EAP Framework: Jan 18 12:08:22.752: EAP-AUTH-TX-PAK:
*EAP Framework: Jan 18 12:08:22.752: eap_core.c:1484: Code:REQUEST  ID:0x 6  Length:0x0297  Type:FAST
*EAP Framework: Jan 18 12:08:22.752: eap_core.c:1422:     Payload:  0134C4C6628B80DC1CD129024E088A67 ...
*EAP Framework: Jan 18 12:08:22.753: EAP-EVENT: Started 'Authenticator Retransmit' timer (60) for EAP session handle 0x78000041
*EAP Framework: Jan 18 12:08:22.753: EAP-EVENT: Started EAP tick timer
*EAP Framework: Jan 18 12:08:22.753: EAP-EVENT: Sending lower layer event 'EAP_TX_PACKET' on handle 0x78000041
*EAP Framework: Jan 18 12:08:22.753: LOCAL_AUTH: Found matching context for id - 319
*EAP Framework: Jan 18 12:08:22.753: LOCAL_AUTH: (EAP:319) transmit event
*EAP Framework: Jan 18 12:08:22.754: AuthorizationResponse: 0x13c713fc
*EAP Framework: Jan 18 12:08:22.754: structureSize................................711
*EAP Framework: Jan 18 12:08:22.754: resultCode...................................255
*EAP Framework: Jan 18 12:08:22.754: protocolUsed.................................0x00000080
*EAP Framework: Jan 18 12:08:22.754: proxyState...................................18:3D:A2:0A:EC:BC-02:04
*EAP Framework: Jan 18 12:08:22.754: Packet contains 1 AVPs (not shown)
*EAP Framework: Jan 18 12:08:22.834: structureSize................................65
*EAP Framework: Jan 18 12:08:22.834: resultCode...................................255
*EAP Framework: Jan 18 12:08:22.835: protocolUsed.................................0x00000080
*EAP Framework: Jan 18 12:08:22.835: proxyState...................................18:3D:A2:0A:EC:BC-02:05
*EAP Framework: Jan 18 12:08:22.835: Packet contains 1 AVPs (not shown)
*EAP Framework: Jan 18 12:08:22.835: LOCAL_AUTH: AAA LOCAL AUTH EAP PKT AVP attribute 4f length 11
*EAP Framework: Jan 18 12:08:22.835: LOCAL_AUTH: AAA LOCAL AUTH TX PKT DUMP code cc id 00 type 2b
*aaaQueueReader: Jan 18 12:08:22.838: LOCAL_AUTH: EAP: Received an auth request
*aaaQueueReader: Jan 18 12:08:22.838: LOCAL_AUTH: Found context matching MAC address - 319
*aaaQueueReader: Jan 18 12:08:22.838: LOCAL_AUTH: (EAP:319) Sending the Rxd EAP packet (id 7) to EAP subsys
*EAP Framework: Jan 18 12:08:22.838: EAP-EVENT: Received event 'EAP_RX_PACKET' on handle 0x78000041
*EAP Framework: Jan 18 12:08:22.839: EAP-AUTH-RX-PAK:
*EAP Framework: Jan 18 12:08:22.839: eap_core.c:1484: Code:RESPONSE  ID:0x 7  Length:0x0006  Type:FAST
*EAP Framework: Jan 18 12:08:22.839: eap_core.c:1422:     Payload:  01
*EAP Framework: Jan 18 12:08:22.839: EAP-EVENT: Stopping 'Authenticator Retransmit' timer for EAP session handle 0x78000041
*EAP Framework: Jan 18 12:08:22.839: EAP-AUTH-EVENT: EAP Response received by context 0x78000041
*EAP Framework: Jan 18 12:08:22.839: EAP-AUTH-EVENT: EAP Response type = Method (43)
*EAP Framework: Jan 18 12:08:22.839: EAP-AUTH-EVENT: Sending method data for context 0x78000041
*EAP Framework: Jan 18 12:08:22.839: EAP-EVENT: Sending method directive 'Receive Packet' on handle 0x78000041
*EAP Framework: Jan 18 12:08:22.839: eap_fast.c-AUTH-EVENT: eap_fast_rx_packet(): EAP Fast NoData (0x2b)
*EAP Framework: Jan 18 12:08:22.840: eap_fast.c-AUTH-EVENT: Process Response, type: 0x2b
*EAP Framework: Jan 18 12:08:22.840: eap_fast_auth.c-AUTH-EVENT: Process Response (EAP handle = 0x78000041)
*EAP Framework: Jan 18 12:08:22.840: eap_fast_auth.c-RX-AUTH-PAK:
*EAP Framework: Jan 18 12:08:22.840: eap_core.c:1484: Code:RESPONSE  ID:0x 7  Length:0x0006  Type:FAST
*EAP Framework: Jan 18 12:08:22.840: eap_core.c:1422:     Payload:  01
*EAP Framework: Jan 18 12:08:22.840: eap_fast_auth.c-AUTH-EVENT: Received ACK from peer
*EAP Framework: Jan 18 12:08:22.840: EAP-AUTH-EVENT: EAP method state: Done
*EAP Framework: Jan 18 12:08:22.840: EAP-AUTH-EVENT: EAP method decision: Fail
*EAP Framework: Jan 18 12:08:22.840: EAP-EVENT: Received get canned status from lower layer (0x78000041)
*EAP Framework: Jan 18 12:08:22.840: EAP-EVENT: Sending method directive 'Free Context' on handle 0x78000041
*EAP Framework: Jan 18 12:08:22.840: eap_fast.c-EVENT: Free context (EAP handle = 0x78000041)
*EAP Framework: Jan 18 12:08:22.840: id_manager.c-AUTH-SM: Entry deleted fine id f700000e - id_delete
*EAP Framework: Jan 18 12:08:22.840: IOS_PKI_SHIM: Session 0x335ee108 deleted
*EAP Framework: Jan 18 12:08:22.841: EAP-EVENT: Sending lower layer event 'EAP_FAIL' on handle 0x78000041
*EAP Framework: Jan 18 12:08:22.841: LOCAL_AUTH: Found matching context for id - 319
*EAP Framework: Jan 18 12:08:22.841: LOCAL_AUTH: (EAP:319) Received eap fail event
*EAP Framework: Jan 18 12:08:22.841: EAP-EVENT: Received free context (0x78000041) from lower layer
*EAP Framework: Jan 18 12:08:22.841: EAP-EVENT: Received event 'EAP_DELETE' on handle 0x78000041
*EAP Framework: Jan 18 12:08:22.841: id_manager.c-AUTH-SM: Entry deleted fine id 78000041 - id_delete
*EAP Framework: Jan 18 12:08:22.841: EAP-AUTH-EVENT: Freed EAP auth context
*EAP Framework: Jan 18 12:08:22.841: EAP-EVENT: Freed EAP context
Stephen Rodriguez
can you post screen shots of the local EAP config on the WLC?
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Sure. I hope it helps.
Now we found the reason.
The WLC doesn´t work with the Sub CA respectively with chain certificates for device authentication.
"Support for Chained Certificate
In controller versions earlier than 5.1.151.0, web authentication  certificates can be only device certificates and should not contain the  CA roots chained to the device certificate (no chained certificates).
With controller version 5.1.151.0 and later, the controller allows  for the device certificate to be downloaded as a chained certificate for  web authentication.
Certificate Levels
  • Level 0—Use of only a server certificate on WLC.
  • Level 1—Use of server certificate on WLC and a CA root certificate.
  • Level 2—Use of server certificate on WLC, one single CA intermediate certificate, and a CA root certificate.
  • Level 3—Use of server certificate on WLC, two CA intermediate certificates, and a CA root certificate.
WLC does not support chained certificates more than 10KB size on the WLC.
Note: Chained certificates are supported for web authentication only; they are not supported for the management certificate."
So the WLC can´t decode the peer certificate.
