problem with WCS, with an error message (Error: Object not found in device)
Philippe C
I  have a problem with WCS, I can not open the window monitor /  controllers with an error message (Error: Object not found in device)  -> https: / / 10.19x.xxx.xx/webacs/switchDetailAction. do? ControllerID = 23735
by  cons I can open the window configures / controllers -> https: / /  10.19x.xxx.xx/webacs/switchGeneralAction.do? command = detail &  ControllerID = 23735
Is there a way to recreate the database or the object? thank you in advance
7 Replies 7
Nicolas Darchis
the best way to "resynchronize", is to do the following :
-Configure->controllers.
Select the cursed controller, in the drop-down menu chose "refresh config from controller"
Then validate that you want to refresh the database of WCS with the current config of WLC.
then you can go to the same page, reselect that controller and now select "audit now".
Hope this helps,
Nicolas
If you find this answer helpful, please rate it
thank you for your help
Unfortunately, the command "refresh config from controller"  does not solve the problem because we have a negative result
(in mode retain or in mode delete) with the following logs :
Log file wcs-0-0.log
10/19/10 12:07:16.333 ERROR[snmpmed] [23] Response VarBind missing for class InterfaceConfig attribute isInterfaceWired
Log file tomcat_localhost_access_log
10.197.xxx.xx - - [19/Oct/2010:12:07:16 +0000] "POST /webacs/switchListCommandAction.do HTTP/1.1" 200 47399
10.197.xxx.xx- - [19/Oct/2010:12:07:16 +0000] "GET /webacs/alarmSummaryAction.do?command=summary&dojo.preventCache=1287490037130 HTTP/1.1" 200 421
What is your WCS version ?
It's a good question
we work with 2 WLC Software version 6.0.188.0 and a WCS Software version 4.2.110.0
WCS 4.2 does not support Wlc 6.0
It precisely gives errors like the one you are seeing.
WCS should always be of a version higher or equal than WLCs
Nicolas
Please rate answers that you find useful
Hi!
I got the same problem with wlc software 6.0.199.4 and wcs software 6.0.132.0. Maybe this would be useful to know.
Same thing Mariya, the WCS version needs to always be greater than the WLC version.
As a general truth, your management system needs to be newer than your managed devices in order to support them. this is always written in WCS release notes.
Nicolas
don't forget to rate answers that you find useful
