10-19-2010 06:02 AM - edited 07-03-2021 07:18 PM
Hi everyone,
Please we need some help.
Yesterday we have a big problem with our wireless infraestructure. For any reason our WLC4400 made a reboot(or something like that) and ours APs(1524) didn't connect again. We try to find the problem and find in the logs the message : "Controller time base status - Controller is out of sync with the central timebase". We don't know if this message have some relation with the reboot.
Another problem was the authentication of our AP. The APs doesn't authenticated to the WLC, we suppose that was because in the WLC the option of allow clients with dinamic IP enable automactly where the system restart and we have clients with static IP(DHCP Server). It's possible avoid to that feature enable automactly when the system reboot??
Can any help with this issue please.
regargs,
JM
Solved! Go to Solution.
10-21-2010 09:58 AM
For the problems with a wlc out of date:
http://www.cisco.com/en/US/products/ps6366/products_qanda_item09186a008082c464.shtml
For the other question, sorry, I don´t understand what is the problem Can you explain better?? My english is still poor
Best Regards.
10-19-2010 11:26 AM
Hi.
First, please make sure your WLC is in time; any wireless infrastructure should be synchronize with a ntp server, first of all because the Ap´s and WLC use certificates to autenticate and register them. Make sure the mac of your MESH AP´s are in you mac-filtering.
Then, if you ap´s not register in your WLC, you can capture the output of the following commands:
- debug capwap events enable
- debug capwap errors enable
With this information, I´m sure we can help you
Best regards.
10-21-2010 05:18 AM
Thanks Raul,
So it is possible that a problem in the synchronize create problems in the authetication and registering of the APs??? why happen this??? It is possible that the controller restart automatic by cause of this problem in the syncronization??? we have all the mac of ours APs in the mac-filtering.
And what about the case of enable automatic dhcp to clients connection when the controller restart. Is there any way to avoid this situation??? We have clients with static IP and we need that they stay connecting all the time.
regards.
10-21-2010 09:58 AM
Best Regards.
10-28-2010 02:36 PM
Raul,
Thanks for the help.
Don't worry about the other problem. I think is a problem of configurations.
regards.
