Problems with association
aashihmin
Visitor
I try to authenticate to the wireless network (AP1200), but my Aegis Supplicant says "Connection failed: unable to associate"
Debug of the AP with options:
debug dot11 events
debug dot11 station connection failure
gives me
_____________________
*Mar 1 01:10:47.135: Client 0040.96a6.b1c2 failed: WDS Down but association attempted with network id configured
Anybody can explain what does that mean?
_________
p.s. Sorry for my poor english
smalkeric
Level 11
Level 11
Try to reload the infrastructure APs. Your problem appears similar to the bug-Id CSCsb56012
Stephen Rodriguez
It means you have WDS, Wireless Domain Services, confiugred on your access point(s). WDS is a mechanism so that AP's authenticate with a "Master AP". The commands that will let you know if you are using WDS are any that have wlccp in them. If you only have one AP, I'd say turn off WDS.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
