Public Access Point Recommendation?
matthyatt
Community Member
A business client wants to provide wireless Internet access to visitors, but wants to be sure that no visitors can access any resources on his LAN. Being new to Cisco, I want to know whether the Aironet 1100 or 1200 include everything we'll need to set this up? If not, what else is required and why?
The existing LAN is pretty straightforward. 10 clients behind a non-Cisco firewall. Fewer than 25 wireless guests will be present at a time in a small area.
I just want to be sure than no wireless clients can access anything else on the LAN / WLAN. They should have Internet access only. I can do this easily with a competing product, but figured this would be a good project to try out Cisco.
Any advice or reading recommendations?
Thanks..
sbilgi
Level 11
Level 11
Craig Norborg
Level 7
Level 7
How exactly you do it will be your choice, but the AP1200 is very well suited for this type of application for sure. It will handle multiple radio's at once if desired and it will do dot1q trunking back to your switches. You could then put all guest traffic on one VLAN and ideally put them into a DMZ on the firewall by having it participate in this VLAN (either via trunking or another ethernet port). The 1200 is quite flexible in these respects.
Thanks for your response Craig. It sounds like the AP1200 can't provide the secure guest services alone, though. No matter what, I'm going to have to buy at least one other Cisco component in order to support dot1q trunking or VLANs, right? I was hoping that I could install an AP1200 without having to change any of their existing non-Cisco equipment.
At present, I believe a standalone AP1200 doesn't include a mechanism to limit wireless traffic to the gateway. I also believe that feature is the only one necessary to protect the LAN from potentially dangerous wireless guest traffic. I'd like to know if anyone has a different opinion. Thanks again.
