QOS config on LAN for WLAN
john smith
Hi Friends,
i need your urgent support for QOS to configure on cisco LAN switches for wireless ssids
i want to use deifferent QOS levels as:
Platinum              -  Voice
Gold                      -  Video
Silver                     -  Devices
Bronze                  -  Employee/Guest
please i am confused to confige QOS on LAN that how i will do that.. shall i configure auto-QOS will be enough for me or
any other advice will be very  appreciated
thanks
Rasika Nayanajith
This is fairly long topic & difficult to give a short answer to this. You have to spend time & understand QoS in general & then try to understand how it works in wireless. Here is some information I can share based on my readings of Cisco config guides/ forums/etc which should help you to understand the topic & configure QoS in your environment.
http://mrncciew.com/2012/11/28/understanding-wireless-qos-part-1/
Rasika
Please mention the Cisco switch, which your are using to implement QoS .
