RADIUS Attribute Supported for Cisco WLC
Arie --
Does anyone know or have the information of supported RADIUS attribute for WLC? Like, session-timeout, accounting, authorization accept, etc.
Thank you
Arie
timpadil
have a look at this document:
http://www.cisco.com/c/en/us/support/docs/wireless/4100-series-wireless-lan-controllers/96103-wlc-attributes.html#c2
check if it helps..
Hi Timpadil,
Thanks for the link.
But do you know what the RADIUS attribute for user session-timeout or authorization accept?
Do you think below information is also can be used in Cisco WLC?
http://www.cisco.com/c/en/us/td/docs/ios/12_2/security/configuration/guide/fsecur_c/scfrdat1.html
Thank you
Arie
