Radius configuration for 802.1X on Radiator
agallo000
Greetings:
We are using Radiator 3.16 (http://www.open.com.au/radiator/) as our Radius server. Its working fine for VPN authentication.
We're trying to use 802.1X on our wireless network. Does anyone have a Radiator config for using EAP-PEAP? We can't seem to figure the Radiator part out.
Thanks.
wong34539
Level 6
Level 6
The IEEE 802.1x standard defines a client-server-based access control and authentication protocol that prevents unauthorized clients from connecting to a LAN through publicly accessible ports unless they are properly authenticated.Refer URL
http://www.cisco.com/en/US/partner/products/hw/switches/ps5023/products_configuration_guide_chapter09186a00805a64d7.html#wp1205506
