Recognize attached antenna
tomasz.puchalski
Community Member
Hi All,
Im looking for possibilities to remote recognize attached antennas to AP1242. I have a lot of devices which not working properly. I think most of them have only one antennas installed , but I cant be sure if its fitted into primary connector.
Do You have any idea how to check numbers of attached antennas and if only one if its fitted into primary connector?
I want to disable diversity when I'll find APs with only one antennas.
regards
Tomasz
Leo Laohoo
Nope.  You need to visually inspect them.
Not only that, you have to ensure the antenna is connected to the correct radio, i.  e.  2.4 Ghz antenna connected to the 2.4 Ghz radio.
