Recommedations for initial WiFi in training room
CHRIS KALETH
Level 5
Level 5
For us to get started with a Wi-Fi training room I'm looking for a general recommendation on what equipment we need.
We would likely install this in our 3rd floor training room. The training room could have up to 20 machines connected to the network.
This floor has (2) 3548xl switches that are connected to our 7th floor core switches (Cat4006) with fiber.
There is no distance limitation with the WLSE and the AP's correct?
Where are the antennae's placed? From our training room to the 3rd floor wiring closet is approximately 125'
How about using this hardware?
CWWLSE-1130-K9 WIRELESS LAN SOLUTION 2.0
AIR-AP1231G-A-K9 802.11G IOS AP W/AVAIL CBUS
AIR-ANT4941 2.2 DBI DIPOLE ANTENNA
srdja
Only distance limit is Ethernet UTP cable limit from switch to AP (100m). For better indoor coverage you should consider AIR-ANT1728 (5.2dbi, omni, ceiling mount).
