Registering the AIR-CAP3702I-B-K9 to controller 5508 not successful
RabbitSF
I have over 30 units of AIR-CAP3702I-A-K9 (primary software version 7.6.120.0) running on our school existing network with the 5508 controller (software version 7.6.120.0). Then I purchased a couple of more APs this summer, they are AIR-CAP3702I-B-K9 (primary software version 8.2.105.100). This morning I was trying to register one of these new APs to our network but it's not successful. The light kept blinking green-red-blue cycle.
Possible reasons why it's not working:
1. AP software version is not the same as the controller?
2. The shipping box of the AP says "Radios Off by Default". Do I have to enable them first?
3. Other reason?
Thanks very much in advance!
The AP cannot be telnet'd into until it joins the WLC.
In order to use B regulatory domain AP's you will need to have the WLC on 8.0.132.0 or higher. Please see the release notes below which mentions this:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn80mr3.html#pgfId-1298773
But first you will need to make sure the AP gets an IP address. Without that it will not even try to do a discover :).
Best Regards,
WiFi Trainers (www.wifitrainers.com)
5 Replies 5
Sandeep Choudhary
1. you dont nee dto have same software version on both AP and WLC. Normally AP downloa dthe image from WLC before joining.
Info: AP must support the SW image of WLC. 3702 AP need minimum version 7.6.100.0 on WLC and that you have it so its not the problem.
2. no
Can you paste the output of these commands:
from AP: sh version
also paste the complete bootup process from console.
From WLC: 1. debug capwap events enable
Sandeep,
the AP could not even get an IP. I can't telnet to it. Any other thought?
Best Regards,
Updated the WLC software to 8.3.102.0. It's all good now. Thanks so much!
Thanks for the update. Great to know that it is working :).
Best Regards,
Learn from the Best To be the Best!
