Regular Packets Drops
Hi Team
I have deployed a cisco 2504 wireless controller along with four (04) lightweight access points (1041N) in four floors respectivly. The clients connect to the AP which is deployed in the lowest floor have regular timeouts/packet drops. Further this particular ap operates at channel 11 and it has around 11-13 rough access points in the same area and operates in channels such as 1,3,6,9,11. The DCA (dynamic channel allocation) is set to auto in the WLC. Further each ap has maximum of 07 -10 clients at any given time and I have changed this particular ap and checked still the result is same hence there is nothing wrong with the ap.
How can i troubleshoot this issue futher. Please advise.
Suthakar
Scott Fella
Well if you can't eliminate the interference, there is not much you can do. The other AP's which you don't manage is out of your control and heck... I bet all the other users on their APs are having the same issue. This is why having an AP with a 5ghz radio goes a long way. You would have less interference on the 5ghz and your client probably would drop.
-Scott
