Repurpose AIR-CAP3702E
General1
Community Member
I was given a Cisco AIR-CAP3702E-A-K9.
I would like to know how I can get into the GUI interface in order to use the access point on my home network.
It's currently running Cisco IOS Software, C3700 Software (AP3G2-K9W7-M), Version 15.3(3)JK.
I watched some videos online of some ppl were able to get into the web interface of the AP to setup the SSID and WPAv2 etc.
However, in my case, I am not able to get into the web interface.
I went into http://ip_of_the_BVI1 However, it doesn't respond!
Thank you.
Ah! W7 missed that.
This might be a security measure before you enable http, just change your secret and see if it works.
I am assuming you can already ping the AP BVI.
(config)# enable secret <your password>
-hope this helps-
Ambuj M
Is the AP In autonomous mode or managed or was managed by controller ?
-hope this helps-
General1
Community Member
It was managed by a controller. But I managed to change the software to an autonomous one (the W7 in the software versions confirms this).
ap(config)#ip http server
System is configured with default enable secret.Please change it before enabling HTTP Server
How can I over come the "System is configured with default enable secret.Please change it before enabling HTTP Server"?
Ah! W7 missed that.
-hope this helps-
General1
Community Member
This is resolved.
Thanks for @Ambuj M 's help.
In summary, the solution are:
1) set the enable password with command
ap(config)#enable secret <pwd_of_your_choice>
2) Turn on the http server/service with the command
And then finally write the change to mem.
