Routing with a ASA 5510
cisco
I have a DSL connection to the internet and a fiber connection back to my main building. Can routing be done with a 5510? I want to push all traffic except for two specific destination IP's out my regular DSL connection, and then when traffic is generated for 172.17.20.1 or 172.17.20.2 it will push the traffic out over the fiber link.
ivillegas
Level 6
Level 6
I think simple Access Lists at the middle router should do. THis would filter as per your requirement. Can you send me the network setup you are using?. That would probably help me to sed you the required configuration.
