RRM
mdshelton1
Community Member
How can you confirm that RRM is on (running)
MikeyD
Sent from Cisco Technical Support Android App
6 Replies 6
Stephen Rodriguez
go to Wireless > pick your netowrk > RRM > RF Grouping.
will show you what WLC are in the group, whom is the leader and the last run time
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Scott Fella
You can look at the gui or issue this in the CLI
(WLC2504) >show advanced 802.11a channel
Leader Automatic Channel Assignment
  Channel Assignment Mode........................ AUTO
  Channel Update Interval........................ 24 Hours
  Anchor time (Hour of the day).................. 0
  Channel Update Contribution.................... SNI..
  CleanAir Event-driven RRM option............... Enabled
  CleanAir Event-driven RRM sensitivity.......... Medium
  Channel Assignment Leader...................... WLC2504 (192.168.201.24)
  Last Run....................................... 39225 seconds ago
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
mdshelton1
Community Member
Is it the "Channel Assignment Mode........................ AUTO"
Auto meaning it is on and fix meaning it is manual not on?
Auto means RRM is going to automatically make changes.  Fixed is basically saying keep the power the same.
Scott
-Scott
mdshelton1
Community Member
Thanks Scott
No problem.
-Scott
